Author Topic: HELPPPP jeep wont start after water episode  (Read 5112 times)
Re: HELPPPP jeep wont start after water episode
« Reply #15 on: May 14, 2012, 06:14:51 PM »
Post up a pic of the white stuff in your throat
Offline BUKI
  • Project Fugly
« Reply #16 on: May 14, 2012, 07:06:33 PM »
LMFAO ;D ;D ;D ;D ;D
Sorry had 2
« Last Edit: May 14, 2012, 07:20:20 PM by BUKI »
Offline Corbitto
« Reply #17 on: May 14, 2012, 07:08:14 PM »
hahahahahaha. wow.  i may never live this down but i will try to get pic of white stuff in my throat lol
Offline BUKI
  • Project Fugly
« Reply #18 on: May 14, 2012, 07:18:52 PM »
OK in all seriousness :-[
if you hydro-locked it you would have bent the valves as too much water in the cylinders. air compresses, water not so much.  This would be very evident when you do a compression test. good compression over 120 in each cyl.
but yes still post the pic.  if you have an abundance of (we will call it) liquid in your intake. pull the throttle body off and let it all dry out.  then squirt carb cleaner into the open intake as someone turns key.  carb cleaner is pressurized and atomizes better than liquid gasoline that is not being run through the injectors.
Offline Corbitto
« Reply #19 on: May 14, 2012, 07:23:18 PM »
trying to figure out how to post pics from my iphone. me cant dooo itttt
Offline BUKI
  • Project Fugly
Offline Corbitto
« Reply #21 on: May 14, 2012, 07:34:30 PM »
a
« Last Edit: May 14, 2012, 07:41:06 PM by Corbitto »
Offline BUKI
  • Project Fugly
« Reply #22 on: May 14, 2012, 07:39:36 PM »
Link No Worky
Offline Corbitto
« Reply #23 on: May 14, 2012, 07:42:23 PM »
Fck. anyone have an email i can send them and post for me. i dunno how to do this.  i click on additional options but doesnt say anything about a pic to upload. i have only ipad or iphone no base computer
Offline BUKI
  • Project Fugly
« Reply #24 on: May 14, 2012, 07:50:18 PM »
send to me.  [email protected]
Offline Corbitto
« Reply #25 on: May 14, 2012, 07:55:37 PM »
sent
Offline BUKI
  • Project Fugly
« Reply #26 on: May 14, 2012, 08:11:11 PM »
that pic is hard to make out but if thats in your tb remove it and dry that crap out
« Last Edit: May 14, 2012, 08:13:42 PM by BUKI »
Offline Corbitto
« Reply #27 on: May 14, 2012, 08:13:09 PM »
doesnt look too bad no?  or is any little bit enough to mess things up
Offline Corbitto
« Reply #28 on: May 14, 2012, 08:28:58 PM »
found write up on how to take apart and clean throttle body. so maybe i will try that and spray in the opening whiel trying to start like u said
Offline Corbitto
« Reply #29 on: May 14, 2012, 08:45:03 PM »
whats the easiest way to get tht crap out.  i dont have any hose or i would prob shove it in and suck on it and emptyminto a bucket
