Author Topic: broke ignition  (Read 1140 times)
Offline Bill
    • MEN with BROOMS
broke ignition
« on: February 22, 2013, 11:19:14 AM »
Between the key cylinder & the ignition switch is the steering column lock. The brittle die cast part on my '05TJ broke.
Chrysler says I have to buy that tiny part as an assembly which includes the steering column for $700.00. Even if I wanted to part with $700.00 Chrysler says there is a back order for 240 (70 in Canada & 170 in the US) with no plan to fill that back order.
Anyone else have this problem?
Chimney Sweep, Wood Stove Installer & Inspector
Offline Bill
    • MEN with BROOMS
Re: broke ignition
« Reply #2 on: February 22, 2013, 01:45:35 PM »
My first thought.... Pick n pull and grab on there
Second.... jb weld that piece back together...  It may last a bit longer.
Third.... push button start with a hidden kill switch
Offline Bill
    • MEN with BROOMS
Re: broke ignition
« Reply #3 on: February 22, 2013, 03:15:31 PM »
well found my answer !!
Modern Motors knew what I needed and ordered it in. I pick it up in an hour !!! It might be a jobber part but at $68.00 it solves the problem of starting the Jeep with a screwdriver.
Kudos to Modern Motors and thanks very much. They have sold me most of my Jeep parts over the years including a lift kit and seats for my YJ.
