Author Topic: NOT able to put in gear.. pls help!  (Read 2532 times)
Re: NOT able to put in gear.. pls help!
« Reply #15 on: April 26, 2013, 11:49:49 AM »
if you haven't.......... change the fluid.  easier than a tranny swap.
start there.
Offline pooljunky
« Reply #16 on: April 27, 2013, 01:41:30 AM »
K 4 hours later transmission is out.. now.. change clutch and release bearing at the same time? Price check tom morning
« Reply #17 on: April 27, 2013, 03:03:30 AM »
If your clutch is out then yes. Change the release bearing at the same time.
I dont know much about AX15's but if the slave is internal may as well change that at the same time too... Also have a look at your flywheel since its all apart now. If theres any damage to that a new flywheel really isnt all that much either... May as well do the work now rather than later..
Offline pooljunky
« Reply #18 on: April 27, 2013, 11:19:29 PM »
Didnt replace the clutch but replaced the release bearing and the transmission... all is good now.. now time to rebuilt the old one.. thanks for all the input guys!
