Author Topic: Joining two tow straps  (Read 5009 times)
Da_chopper
« Reply #15 on: May 30, 2006, 10:45:26 PM »
Quote from: "HIWYH8R"
Ok but then what do you use for tow points then? Most people I've seen use shackles on their bumpers and if one breaks same thing happens, a projectile. Same as hooks, even bolted with Gr.8 bolts.
First it is normally the strap that snaps, not the shackle or tow hook.  If you have a shackle in the middle of two straps it will fly to the other side!  If it is mounted properly to a bumper it, will probably stay there.
Also, it best to have less flying pieces as possible.
I only use 3/4" shackles and am worried when I see people using 1/4" shackles  :roll:
The tow hook arguement makes sense to me, as I've seen one bend.
ps, your shovel may be nicer, but mines more muddy  :twisted:
Offline JohnB
« Reply #16 on: May 31, 2006, 10:11:59 AM »
Yes, it is important that the rigging hardware and the attachment points are substantially stronger than the strap or cable.
