Author Topic: Short shifter DIY  (Read 1169 times)
Offline Marco
Short shifter DIY
« on: June 19, 2013, 09:38:16 AM »
Decided to try this and see if it works. My transmission was out anyway from a clutch job but its not necessary. Seem to make the shifting shorter but i havent tried it on the street yet haha
Making a template:
cut up some 1/2" strips i found at Can tire for $3
weld strips together
cut small piece of rod for the extension
cut the shifter rod above the ball somewhere and ad in the extension piece you cut. (1/2" to match the the other spacer metal)
as long as you have a 1/2" spacer of some sort its a fine.
test it out!
locked and loaded
