Author Topic: engine swap. 2.5l to 4.0 questions.. and help?  (Read 5060 times)
Offline pooljunky
Re: engine swap. 2.5l to 4.0 or 318?
« Reply #15 on: September 27, 2013, 07:29:49 PM »
So just to make sure the wiring harness for my 2.5l tj will work for a 4 litre cherokee engine?
Offline pooljunky
« Reply #16 on: September 30, 2013, 10:49:42 PM »
anybody got any idea how I can add 2 injectors to my wiring harness of the 2.5 for the 4.0 litre?
and anybody would be kind enough to help me weld the new engine mounts that has done it before?
HELP! lol
thanks guys
« Reply #17 on: October 01, 2013, 09:04:07 AM »
And for the 5.2 I can use the ax 15 I just need to change the belhousing from a Dakota. .
when you find one let me know. i've been looking for a 5spd out of a dakota for 2 years now.  they are RARE to find. probably because its a good tranny and good motor combo ;)
Re: engine swap. 2.5l to 4.0 questions.. and help?
« Reply #19 on: October 01, 2013, 12:35:26 PM »
http://www.ebay.com/itm/Dodge-Dakota-AX15-to-V8-V6-3-9-5-2-5-9-Bellhousing-94-95-96-97-98-/221240119783?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ADodge%7CEngine+-+Liter_Display%3A5.2L&hash=item3382f051e7&vxp=mtr#ht_92wt_904
i gave up on ebay a while ago because they won't ship to canada half the time.
same with this on; they won't ship to Canada :( i've been looking (not very hard) on kijiji and waiting for them to be parted out.  mostly i'm lazy haha
Offline pooljunky
« Reply #20 on: October 01, 2013, 04:48:33 PM »
Lol well this is getting a bit off topic lol for the dakota bell housing im pretty sure picknpull would have quite a few of those.
Now abput some welding?
« Reply #21 on: October 02, 2013, 12:32:26 PM »
You best bet would be to measure a TJ that has a 4L from the factory.
As for the wiring harness, I know it can be done as that is what was done when I swapped in a 4L to my YJ. However, I had National 4wd do the swap for me
Offline pooljunky
« Reply #22 on: October 02, 2013, 12:35:35 PM »
Welding is now covered.. but lol just need to figure out the injectors and the pin location for number 5 n 6
Offline pooljunky
« Reply #23 on: October 06, 2013, 10:51:04 PM »
Ok guys.. all that has been covered and fixed. New issue...  the transfer case allignment to the rear pinion on the dif.. how is it supposed to be alligned. .like straight? so I would assume that the bolts of the transmission does not allign on the plate for the tranny?
ANy help on that?
