Author Topic: Wet floor  (Read 879 times)
Offline HikingViking
Wet floor
« on: May 24, 2020, 08:44:23 PM »
So after the rain we had recently I noticed my drivers side rear floor was wet. I thought maybe it was coming from under neath, crawled under and couldn’t see anything that would cause it. The weather strip seems fine. Has anybody experienced this? A little advice would be greatly appreciated.
Kalvin
White 2015 JKU on stock 18s with cooper discoverer at3, smittybilt xrc front bumper
Re: Wet floor
« Reply #1 on: May 24, 2020, 11:20:00 PM »
I’d check the seals on the hardtop. If you have a soft top look for any gaps or zippers that are un done
Offline MattMan
Re: Wet floor
« Reply #2 on: May 26, 2020, 06:09:10 PM »
I struggled with that problem with my hardtop, where back upper corner of the drivers door meets up.
There’s a pathetically poor foam seal that wears out easily. Mopar reseal kit for the freedom tops has what’s needed.
My seatbelt was also quite wet when I extended it
« Last Edit: May 26, 2020, 06:10:48 PM by MattMan »
MattMan
Re: Wet floor
« Reply #3 on: May 26, 2020, 06:51:49 PM »
Thanks for the tips! Much appreciated! I think I will pick up that kit and see if it helps anything.
Kalvin
