Author Topic: High pitch squeel  (Read 5886 times)
High pitch squeel
« Reply #15 on: September 25, 2006, 12:24:49 PM »
Quote from: "bnine"
Yeah, front driveshaft.
Pull it and take it to DSI (drive systems inc)
252-2515
I got my CV & U-joint rebuilt on my front Drive shaft... at DSI... $185 TX in last spring (it was a DSI custom shaft originally).
Offline Flathead
High pitch squeel
« Reply #16 on: December 07, 2006, 09:39:23 AM »
Just had my front drive shaft replaced under warranty (03 Rubi).  Only 58,000 km.  Same squeal noise as previously mentioned.
Joel
High pitch squeel
« Reply #17 on: December 08, 2006, 02:41:55 PM »
OUCH is right on that price Chris.
DSI
DSI
DSI
Tom :lol:
Offline DGenR8
High pitch squeel
« Reply #18 on: December 08, 2006, 03:32:01 PM »
I bought the rebuild kit from DSI ($35.00 I think + u-joints) and did it myself.
If you haven't done it yourself I recommend you do. At some point you will be doing it on the trail. Best to learn in the comfort of your garage the first time.
_/l ,['''`'''],
l---L--OllllllO-
81 CJ7
TJAB
High pitch squeel
« Reply #19 on: January 07, 2007, 09:42:38 PM »
It sounds like angry sparrows.  Basically a worn out centering bearing in the CV Joint.  I have/had the exact same problem, but dropped out the DS and repaired it today.
Don't pay somebody to do it for you.  For $13 each for 3 U joints and about $35 for a center bearing repair kit (or $70 ish for a new one) you can do it yourself very easily even if you have little to no mechanical experience.  Try this link out as it helped me a lot.
http://www.stu-offroad.com/axle/driveshaft/driveshaft-5.htm
+ you don't need the U joint press.  You can do the same thing with a vise or pound them out/in with a hammer and a socket (which is what I did).
