Author Topic: Black box  (Read 2993 times)
Offline Domengus
Re: Black box
« Reply #15 on: May 05, 2011, 08:49:15 AM »
Ya I was wondering cause I don't have a full six hour day to work on my bumper, and the canister has to be moved to a spot where the new brackets can fit so I thought if I could remove it for a day or two I would be fine; it's a 2000 Cherokee sport 4.0 i6
Take me on your buggy take ta take me on your buggy, they be like dan, what, can you take me on your buggy, you know why cause everyone loves muddin',  and all I need is a lady to come up to me and you you and you be ready for some muddin'
Re: Black box
« Reply #16 on: May 05, 2011, 09:19:35 AM »
I have a 2001 and had to leave it disconnected for a few days. The vents didnt work just defaulted to the defrost. It wont hurt your jeep any for a couple days, just wont have vents. Simplest solution was already given though, just temporarily use some zip straps to hold it to something till your bumpers done. I ended up pulling the hard line back up into the engine bay and cutting it shorter. Then i took the rubber end that connected to the baseball and put it on the shortened line. The canister now sits up on the fender wall under the hood. Vents work again!
Re: Black box
« Reply #17 on: May 06, 2011, 08:24:34 PM »
I relocated the reservoir to under the coolant pressure bottle. Fit nicely there, not sure why they didn't do that from the factory.
For the same reason they use regular head bolts on the whole transmission except for the one you can't see up top.  ::)
