Author Topic: Need some lift advice for my XJ  (Read 2636 times)
Offline dubbleJs
« Reply #15 on: December 26, 2006, 03:07:23 PM »
So did you just back the bolt out til it hit the hitch then cut enough off so it wasnt still holding the leaf on?
TheCustomizer
« Reply #16 on: December 26, 2006, 04:10:37 PM »
Gimme a buzz Dub, I can help you with that this week if you can make it out to the shop.
Offline cotaman
« Reply #17 on: December 26, 2006, 06:34:32 PM »
i just backed it out enough to get the blade in so the threaded end ( with the nut still on ) was supporting the spring, cut it then pulled the remainder out while supporting the spring if still under tension
Offline XJHERO
  • Soberphobic
« Reply #18 on: December 27, 2006, 12:48:34 PM »
Check the clearance for the bolt to move up in side when the shackel moves up, i think the bolt only goes in one way starting from the gastank side, nut will be on the outside....................I think...................... :shock:
DD
Get at me Wolf
Offline cotaman
« Reply #19 on: December 27, 2006, 12:55:55 PM »
xjhero... remember on my heep.... there wasn't any clearance issues if the bolt was the right length.... so the bolt could go either way... nut in or out
 :D
