Author Topic: 2.5 4cyl in early YJ's  (Read 1007 times)
Offline chrispl
« on: July 28, 2007, 01:37:20 AM »
how are the early 2.5 4cyl's with 5spd trannies in the early YJ's? hold up well with 35's? hows the reliability? and mods to make them better?
95 cherokee
Offline dukabor
« Reply #1 on: July 28, 2007, 03:36:47 PM »
you want Fuel Injection for sure.....
mine is still going strong, but I am a bit of a freak for maintenance, I run synthetic oil in the motor, and Syncromesh in the tranny.... I have only minor mods to the motor (4.ol TB, header, minor airbox mod) and have no issues at all.... though I will be the first to admit I do not break land speed records, I am able to cruise at 75 mph..... not sure if I want to go any fater in an SOA YJ on 35's
....Another major factor is gearing, the 5spds came with 4:10's and while that may be OK to get by with 33's, I went to 4:88's and have never looked back.....
If I were to do any more mods, it would be an electric fan, and maybe a cold air intake..... and when it was time for a rebuild I would go to a bit stronger camshaft (Hesco makes a few different options)
Many people will tell you to bypass a 4banger and do a 4.o or even a v-8 swap.... but my bang for the buck is on the 2.5 4cyl.... I can crawl like a bandit with the gears and the 4:1 in the Transfer case, and it does not eat parts!
my 0.02$ .... but I am biased ;)
Offline chrispl
« Reply #2 on: July 28, 2007, 04:05:04 PM »
i'm mostly concerned about power..
95 cherokee
Offline dukabor
« Reply #3 on: July 28, 2007, 05:37:55 PM »
It does have less power than the 6cyl for sure..... IIRC it is like 140 horse to 190 horse.... I think..  someone will correct me if I am wrong on those numbers
Offline Gearhead
« Reply #4 on: July 29, 2007, 01:15:50 AM »
I've got a 2.5 YJ as well as a 4.7 stroker YJ , The 2.5 has a 4.0 throttle body and a flowmaster muffler , 4.88 gears . It's easy on fuel and will go as fast as it needs to go ( spring over on 33's ). The stroked 4.0 is a beast , only runs on premium and is thirsty. I like em both. The 2.5 is a cool little engine , I wouldn't turn my nose up at one ,............ well , ...... the throttle body version is not as powerfull as the later mpi model , my 88 Comanche has that engine , it uses more fuel and is less fun to drive.
