Author Topic: tj clutch slave  (Read 1293 times)
Offline TJ54
tj clutch slave
« on: September 10, 2007, 06:20:27 PM »
97 tj 4 banger 5 spd
The clutch slave cylinder is leaking. It's the external kind, I took it off, I'm 100% sure it's leaking.
The haynes manual says it is not servicable and the whole master/slave assembly has to be changed.
Is that right :?:  or is there a way to change just the slave :?:
will I have to go to the dealer for parts or will the local NAPA have it. :?:
TIA
Ian
Dragonmaster
tj clutch slave
« Reply #1 on: September 10, 2007, 06:43:42 PM »
It is possible to replace just one of the components, however you will never get all of the air bled out and have a 100% nice feeling clutch again.  Best to get the whole unit.  Napa didn't have them when I was looking a year ago, however have heard they have them now.  Someone said that the dealer is still the cheaper option (it happens occasionally).
Offline TJ54
tj clutch slave
« Reply #2 on: September 10, 2007, 06:54:31 PM »
Quote from: "Dragonmaster"
Thanks.I'm ok with it not being 100% if i can save a few bucks. I'll check out Napa and the dealer tomorrow.
I just bought a tps from the dealer it was about $80. NAPA wanted more than twice as much.  so I always check both for pricing. "cause every once in a while you get a surprise :lol:
Offline Gearhead
tj clutch slave
« Reply #3 on: September 10, 2007, 07:18:02 PM »
You can replace either part , I've done it many times with success.
tj clutch slave
« Reply #4 on: September 10, 2007, 07:59:40 PM »
Quote from: "Gearhead"
Not on the newer external slave models.  They are in fact not servicable as there is not a proper bleed screw.
Ian, you have to go to the dealer and when I replaced mine it was about $200.  It sucks about the cost but it took about as long to install as an oil changed.  It comes filled with fluid already to go
Offline TJ54
tj clutch slave
« Reply #5 on: September 10, 2007, 09:37:19 PM »
Thanks Scott, I was looking for the bleed screw. I couldn't find it. Now I feel a little better :lol:
Offline Gearhead
tj clutch slave
« Reply #6 on: September 10, 2007, 09:54:56 PM »
Quote from: "BlackYJ"
The absence of a "proper" bleed screw has never been a problem for me . I have changed several , usually spending very little time getting the air out.
My 94 YJ(255,000 km) has an external slave , that one was  replaced two years ago , got it at Auto Value $60 , had it running in minutes. The same vehicle...... replaced the clutch master cylinder last year with a plastic ( same as stock ) part , it lasted less than a year . The plastic master cylinders have been upgraded to aluminum , that's what is in it now , $135 at auto value , btw, .... Auto value warrantied the plastic cylinder , I had to pay a difference of $5.
My 88 YJ used to have an internal slave cylinder , last year I built my stroker and converted to external slave while I was re-powering it / converting to fuel injection. The slave cylinder came from ........... Auto value , the line , I made up , bleeding it ?  piece of cake.
Oh ,  I should mention ,   the 30+ years as a motor vehicle technician helps,  from time to time .......... even Waaaayyyy before there was internet.
Offline fony3
tj clutch slave
« Reply #7 on: September 11, 2007, 12:27:31 AM »
My master cylinder went in July on my 02 TJ, it cost me 355 from the dealership (entire unit).
tj clutch slave
« Reply #8 on: September 11, 2007, 07:53:54 AM »
touche.  I am going to go sit in the corner now  :oops:  Damn those old guys knowing all the tricks  :D
Offline TJ54
tj clutch slave
« Reply #9 on: September 11, 2007, 09:39:37 PM »
Thanks for everyone's advice.
After searching around for a while. I found an aftermarket Slave cylinder. NAPA did not have one, but they did list a Master Cylinder but it did not come with the slave. Canadian tire had nothing, I assumed the dealer would only have the complete assy.
Town and Country In Cochrane (Auto Parts Plus ) had one listed and got in for me in a couple of hours.
For reference it is
Part # SC130548 By "Wagner Brake Products" which is distributed by "Federal Mogul"   Cost was $95
It was easy to replace, about 1/2 hour, all I need was a 14mm wrench to detatch it from the clutch housing. A small nail and hammer to remove and re-install the pin that attaches the hydraulic fluid line and some brake fluid. Instructions on bleeding it are included.
I went for a short drive, the clutch feels just like new.
