Author Topic: Stereo in TJs  (Read 2743 times)
Offline calltrex
Stereo in TJs
« Reply #15 on: November 30, 2007, 09:12:46 AM »
Quote from: "fug"
What did you put in the front?
I am going to have to replace my speakers soon... 3 years of drowning out wind/tire noise etc has taken its toll on the stockers.
I put xplod 220w 5 1/4 speakers in front
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline fug
  • Airdrie Pick n Pull
Stereo in TJs
« Reply #16 on: November 30, 2007, 09:22:52 AM »
Did you use one of those fancy plates you can buy? or just work it out on your own?
I've seen the plates and I just can't see that it would be too hard to figure something out on your own.
Fug
TJ Rubicon
Offline calltrex
Stereo in TJs
« Reply #17 on: November 30, 2007, 10:31:13 PM »
Quote from: "fug"
those plates will not work on 03-up
you would have to modify them
........___________
.../""""/........J
Offline calltrex
Stereo in TJs
« Reply #18 on: December 01, 2007, 08:07:34 PM »
got new head unit in. sounds good
next project is changing out the stock 6" sub with a 8" sub
........___________
.../""""/........J
Offline calltrex
Stereo in TJs
« Reply #19 on: December 01, 2007, 08:09:04 PM »
if anyone is change stereo with 2003 and up u need to get a antenna adapter also
........___________
.../""""/........J
Offline apex
Stereo in TJs
« Reply #20 on: December 01, 2007, 08:27:30 PM »
did you have to get a adapter clip for the harness?
Offline calltrex
Stereo in TJs
« Reply #21 on: December 02, 2007, 12:02:14 AM »
Quote from: "apex"
ya i did to make it easier
you dont have to though.
........___________
.../""""/........J
shibby
Stereo in TJs
« Reply #22 on: December 04, 2007, 03:24:43 PM »
If you do decide to take apart the stock subbox and replace with an 8inch sub, could you take pictures? It'd be interesting to see what it looks like inside there, might be worth my time to add a little bit more boom. Would also be interesting to see if there's any way of connecting an RCA to the stock amp as apposed to the line converter it's gotta be using now (considering it's connected to the rear speaker outputs)
