Author Topic: Anyone need anything?  (Read 810 times)
« on: June 29, 2008, 01:47:28 AM »
Might hit PnP today for a few things.  Anyone want me to keep an eye open for anything specific?  Heading out around 1:00 ish.
Gear shifter
« Reply #1 on: June 29, 2008, 08:25:27 AM »
Ford NP435 Transmission shifter
Found in Ford trucks, 66-92
Identification
This transmission is 10.8" long and features an aluminum top cover that is retained by eight bolts. The NP435 case is of cast iron.
The Ford NP435 has a 1-1/16" diameter, ten spline input shaft that has a stick-out of 6-1/2" from the front face of the transmission. The pilot tip of the transmission measures .668". The front bearing retainer flange measures 4.850" and the bearing retainer tube is 1.430" in diameter. The front bolt pattern is the symmetrical Ford "butterfly" pattern; roughly 8-1/2" wide by 6-5/16" tall. The input shaft stick-out length is 6-1/2".
Offline i_go_commando
Re: Anyone need anything?
« Reply #2 on: June 29, 2008, 10:20:49 AM »
electric power steering pump from a toyota mx6? will pay for your trouble. a twisted ankle does not make for good PNP ing. Its on a second generation up till about 96 i belive.
keith
