General Forums => Chit-Chat => Topic started by: JENSSEN on October 21, 2008, 03:37:11 PM
Hey Guys,
Just chatting with Kevin H. in regards to HRC 2009 and we talked about the lack of 40" and under trucks in the 2008 competition,.. Now my question what made people not enter in HRC? Did the course look too hard, did the spy pics spook people? Just not finished the build? There are probably a lot of reasons why people didn't opt to enter but I am curious if you'd share.
Or who is planning to attend 2009?
Did you see the number of carnage from that weekend? My feeling, that course was built for 40's and built to destroy your rig. If your a spectator that stuff is fun too watch, not so much for for the competitor that has to fix his rig.
Not even thinking of attend HRC, but I am going to The Alberta Safari Challenge, Off-Road Expo in Abbotsford, Red Deer and SK. 8)
There were many trucks that escaped with out any damage,.. If I had taken it a bit easier I would of been there too,.. I lost my spider gears and a driveshaft,.. and some glass but thats just how I drive,... someone who was a bit more mild with the skinny pedal can go through aok ;)
So how would you change it?
If i compete, its to win.
Damage is a 'given'. i am mechanically inept so shelling out a couple grand to fix my rig after one weekend has zero appeal for me.
If i could fix my junk and get parts at wholesale prices, than i would be there to win.
8)
Of course, no rig anymore so... :'(
Buy my TJ Tom!!
^^And that's the purpose of competing, you go in there thinking that you have a shot at winning.
HRC has 2 classes below 40" tires and unlimited. It's a no brainer who's going to win between a guy running 33's vs 40's, when the course is built for guy's running 40" tires, climbing over buses, etc. :o
Why bother competing, if a guy doesn't have a chance? Unless your name is DOM (I did that obstacle with my 31" tires). ;D ;D
HRC should have 3 classes:
Unlimited = Purpose built buggies running 40" - 99" tires with the latest and greatest technology.
Pro Modified = Modified factory vehicles running 37"-40" tires and heavily modified.
Pro Stock - Street driven rigs running 33"-36" tires.
Run the Pro Stock class in 80% of the course and the other 20% as bonus points. A separate Pro Stock class will allow newbies or someone who doesn't have endless amounts $$$ a chance at competing.
my .002$ :P
I am glad to see everyones honesty on this thread! It wasn't designed to call anyone out or to challenge people to get out there,.. I just would really like to see this event grow and would love to see it wildly successful but feedback is required to make that happen. I am not a Highriders club member or an organizer but I did want to see what the community wanted in an event. So keep posting up the thoughts and opinions! Since reading all the posts on all the forums I have had soooo many ideas running through my head to pass on to the HRC staff and event organizers
I agree with Joel on this one. It would be nice to see a course more designed for the smaller rigs. A lot of the small rigs are driven to the events and they have to drive home after the event, so I think that needs to be kept in mind.
So if there was a under 35" Class and spomthing like this:
Run what yah Brung
Minimum Requirements
• Helmet
• Seat belts
• Mechanically sound
• Tow points Front and rear
• Valid drivers license
Maximum
• Tires 35” and under
• Maximum 1 traction added (stock LSD’s not included)
• NO POWER ADDERS
• Custom Fabricated chassis no allowed
If there was a course is designed for lightly modified stock street legal trucks, with potential for scratches, dents, light body damage (Mirrors, trim) nothing worse than a good day wheeling. A course is built for driver technique, and finesse. As in any 4 wheeling runs there is a chance of injury so Helmets and personal protective equipment would required.
Suggestions? Something to add or remove?
37" and under
Unlimited = Purpose built buggies running 40+ tires with the latest and greatest technology.
that looks like like a good class setting. What about tracks? ::)
** hows a guy running 33's going to compete against a guy with 37's? unless the 37" is are open & the 33" is fully locked...
So if there was a under 35" Class and something like this:
Run what yah Brung
Maximum
I think what you are suggesting would be great and I think lots would show up to run the course. How many would fit the class except that they have two lockers? I only have one, some have two that are selectable and could disable one but a few with front lunch box lockers may be excluded by that one rule. Just something to consider.
These are just thoughts at the moment,.. If the community has ideas I will try and put it all in a package and pitch it to Kevin,..
Now if that were the case the course would have to be built,.. so then we'd need volunteers,..
That's why the 3" spread between the two classes make sense.
33 - 36
37 - 40
There's a huge difference in the rig's capabilities between 33's and 37's. every inch counts. ;D
Regarding the course, if you build the course so that 60-70% of it is do able by 33-36 group and make the rest bonus sections, then it makes it easier to setup the course.
Run what yah Brung
• Helmet
• Seat belts
Maximum
• NO POWER ADDERS
I think something like this is definitely in the right direction with the emphasis on finesse. I would remove the limit of lockers because there are a lot of jeeps locked front and rear ie rubicons, and if you want it to grow that is going to be a limiting factor. My YJ has ARBs front and rear.
Also, I think it should be 35" and under because a 36" irok measures .1-.2" different than a 37" irok so they are essentially a 37 in my opinion
Ok I have an idea,.. if there is truly interest in the smaller tire class, let me shoot out an idea,.. Now keep in mind it takes a lot to make a course, set up the events, get it all rolling so,…
Make it hard for Kevin to turn down,.. Lets say Min 10 Rigs , Max 20 ,.. now here is the trick each team entered will offer up 2 People as volunteers for a few weekends for track prep or whatever Kevin and the HRC team needs to get done for 2009. Pony up the dough for the entry fee, Line up your team volunteers and get it all set up with Kevin by say December 15th and then maybe the HRC will go for it. There was in the past a smaller tire class but there was a lot of people who said they would be there but no one showed,..
Who'd be in?
[quote name='locknload' date='Oct 24 2008, 03:56 PM' post='108134']
Great comments the HRC organizers are listening and aware that the “Grass Root Competitor” needs to be included to keep the comp scene alive and thriving into the future, but making it work is a huge hurdle. As it sits a well equipped stockish rig can be competitive at HRC. Tim and Jennsen finished in the middle of the pack in 08 running the same course as the big dogs. Keep in mind they are still competing in their own class. The cup is open for all trucks regardless of class so to be fair, everyone has to run the same course.
Can a rig with 35’s or 37’s win the cup? The odds are against them but it could be done. As previous comps have shown anything can happen over the 2 days.
I encourage all rigs that fall into the pro stock class as it sits to enter and give it a shot. The course is tough but it’s doable. We go to great lengths on the course design as to not to wreck your trucks but still make it tough and exciting. We leave the truck thrashing up to you. What do have to loose? The entry fee is only $75 with 100% payback plus we usually collect additional prizes and spread it around the best we can.
It may be that HRC isn’t the comp for stockers or for a beginner, for those who think it’s to extreme there are other comps to cut you teeth on eg: W.E. Rock, Mud Bogs, Tough Truck
If someone or group was step up to the plate we would consider a separate event or an event within an event to cater to the smaller tire group. This needs to be done within the next couple months. We are at our limits of staff and budget as it is. We also have to answer to insurance companies, county, DOT, police, neighbors etc etc etc
Here’s what I can say for certain for what’s planned for HRC09 on July 4th and 5th
which by the way is THE GREATEST REDNECK SHOW ON EARTH
Format will stay similar to 08 but the trench is gone and the obstacles will be tuned down a little to allow for more speed
In tribute to the U.S. July 4th holiday - free entry to any U.S. competitor
LIVE BANDS Saturday eve (kick-arse recording artists are already booked)
Short Course Racing
Quad Barrel Racing
Burnout Comp
Vintage Car/Truck/Bike/Hot Rod Show all weekend
Kevin
[/quote]
Randtarded has a great response here!
http://www.evolutionmachine.com/index.php?...40&start=40
