4x4 Related Groups => Tech Talk => Topic started by: Jeepster on April 14, 2009, 05:18:21 PM
I just got some new 2 Ton Axle Stands... that enough to hold up the rear of my YJ ?
yes. 2 ton = 4480 lbs. That shold be enough to hold up your entire jeep.
Thanks , I didnt feel like getting crushed :)
Once mine is up and lifted, I shake the crap outta it. At 160lb, I'm not big enough to pull it off the stands, but I can shake it around enough to be safe that it will stay put. If it stays, I crawl under happy as a lark.
Actually 2 ton = 4000 lbs. ;D
ton = 2240 lbs, right?
tonnes = 1000 kg, right?
yup depends on the system you use, english vs imperial i think.
The 2,240 lbs is a long ton or UK ton, tonne or metric ton = 1,000 kg or 2,200 lbs, and short ton or ton = 2,000 lbs.
Sorry for the hijack
the 2 jack stand will be more than enough to support the rear of the jeep
i had a dream last night about being crushed while changing my oil... i turned on my shoulder, and apparently held my truck up... and screamed like a girl. off topic, but made me flash back to that dream.
