4x4 Related Groups => Tech Talk => Topic started by: dunl on April 30, 2009, 07:31:58 PM
Title: wheel spacers....the good, the bad, and the ugly....
Post by: dunl on April 30, 2009, 07:31:58 PM
Tell me all about them.  Safety? Wear and tear? Pain in the butt?
I'll read everything you wanna tell me about them.  :)
Title: Re: wheel spacers....the good, the bad, and the ugly....
Post by: WhiteOut on April 30, 2009, 08:00:13 PM
I have a set of Spidertrax on my ZJ right now.  Wheel and hub centric, as long as you torque them right and use locktight you should have no problem.  I really like the wider stance it gave my Jeep.
Post by: SwampSinger on April 30, 2009, 08:03:52 PM
I have 1.25 wheel spacers , offset steely rims and 37" 13.5 fat bias ply tires...
I run this on a highly modified HPD30... the only thing i wear out is unit bearings and balljoints... I don't drive it every day so it's not that bad...
It makes it a little wider/ more stable... I have more clearance for the tires when I turn or stuff em in the wheel well... I like it.... I have no issue with them on my rear axle.
I run these ..
(http://www.spidertrax.com/core/media/media.nl?id=26&c=407909&h=8662e0eaaa7c276f7078)
Post by: SwampSinger on April 30, 2009, 08:05:07 PM
same ones as Fraser  ;D
Post by: dunl on April 30, 2009, 08:16:29 PM
Anything else bad about them?
Post by: WhiteOut on April 30, 2009, 08:20:18 PM
My unit bearings are on their way out.  Hopefully not tooo much $$
Post by: JackstandJohnny on April 30, 2009, 09:02:26 PM
they are 100$ each for parts and can be done in an hour or two by someone who's done them and has the correct tools
Post by: Vinman on April 30, 2009, 09:32:58 PM
I picked up a CJA member (can't remember his name) a few years ago on the side of 32nd ave with a white 3 wheeled TJ Sahara.
His front Spidertrax spacer fell off. He did say the manufacturer warrantied it but I don't think I'd run any spacers unless I'm truly in love with the wheels.
Vince
Post by: rangerdanger on April 30, 2009, 09:33:30 PM
The bad, getting a ticket unless you also buy wider flares  :'(
Post by: Bushluver on April 30, 2009, 09:42:16 PM
I'll be running 1.25" Spidertrax spacers on the rear of my TJ w/ 37's as well.
And I've been running 2" Aluminum spacers on the rear of my Duramax for about 3 years without issue.
Locktite, proper torque, and should be worry free.
Post by: JK2008blckblck on April 30, 2009, 10:22:54 PM
for the price of spacers you could pick up some decent procomp wheels that have the right backset. thats what i did for my jk, same price, custom look. thats just my $0.02
Post by: esi on April 30, 2009, 11:36:42 PM
Wheel spacers shouldn't be as much as ProComps. How much did you pay for the PCs?
Post by: WhiteOut on May 01, 2009, 12:43:53 AM
The rockcrawlers are ~$60 USD each, so $360 CDN for 5 as opposed to $240 for 4 Spidertrax spacers shipped.
Post by: esi on May 01, 2009, 01:07:54 AM
So $195 for toplines isn't bad. They're not blue, but who can see through the wheel
Post by: WhiteOut on May 01, 2009, 01:25:56 AM
For the $45 difference I'll take the wheel and hub centric design of the Spiertrax
Post by: sn4cktime on May 01, 2009, 03:34:25 AM
1.5" SpiderTrax, front and rear.  Helps with inner fender rubbing when stuffed.  Unit bearings and balljoints are still good - for now...  But I'm pretty sure the 35 x 12.5's being 110lbs each screw up my rig's parts more than the extra 3" width.
Post by: w squared on May 01, 2009, 06:32:32 AM
The amount of wear put on bearings and balljoints is the same regardless of whether you have a wheel that has 4.5" backspacing, or use a wheel with 6" backspacing and add a 1.5" spacer.
The increased wear is simply due to leverage. It doesn't matter what method is used to reduce that backspacing - it's just a matter of how far "out" from the bearing the force is exerted.
I don't run spacers myself, but from the reading I've done, there are two things that I've seen to watch for.
#1. Get a quality spacer that comes with lugs on it. The ones that try to fit between your wheel and the hub are not something you want on your rig. The pic that swampsinger posted is an example f the type that I'd look to run.
#2. Torque wrenches and loctite are not optional. They're required. Then agian, torque wrenches should be used ANY time you put a wheel on, spacers or no.
Post by: hps4evr on May 01, 2009, 06:06:24 PM
when installing the wheels spacers. please make sure the surface they are sitting against, like the brake rotors or drum, is clean and flat. as well remove the clips that surround the lug nut studs on some of these vehicles. they will make the spacer sit crooked and cause many a headache later on. as other mentioned, torque them down, use locktite on the factory studs holding the spacers on.
it comes down to how much you like your current wheels. and what back spacing you allready have. if you need a wider rim then wheel spacers cant help you there. if your rim and tire combo is fine, you just need an extra inch or so of width then spacers it is.
Post by: JackstandJohnny on May 08, 2009, 10:26:13 AM
its all good buddy................ just remember, YOU can take your wheels and wheel spacers off when we do your unit bearings why i sit back and drink beer.........
just so yo know how much of a bitch they are i won't roll in the air tools till AFTER you ahve the wheels off ;)
blahahahahaha, don't worry should be quick. clean your jeep up real good though. i don't want mud falling on my face when we start hitting $h!t with a hammer
Post by: WhiteOut on May 08, 2009, 12:13:18 PM
Ok, the wheels and spacers are torqued to spec so they will come off easy and a bit fo heat will get the locktite to loosen up.
