4x4 Related Groups => Tech Talk => Topic started by: 2grand4u on December 22, 2009, 06:08:22 PM
Title: jeep tj fuel pump
Post by: 2grand4u on December 22, 2009, 06:08:22 PM
so i took out my gas tank from under my jeep and relocated it to the back of my truck to gain a wack of rear ground clerence, i took my fuel pump out so i could clean the filter and tank. i went and put it all back togeter and turn the truck over for ever trying to get gas to the motor, then after it didn`t start i went and pulled the fuel line off the pump to see if the pump was pumping fuel but it`s not so i took it out of the tank and put 12 volt strait to the pump, you can here it pumping but still nothing comes out, WTF.
a new pump is just shy of 600 bux
any one have any ideas i`m stumped and don`t have 600 bux it,s that time of the year
Title: Re: jeep tj fuel pump
Post by: Immortal on December 22, 2009, 06:32:14 PM
is the pump running in reverse? or is it even possible to reverse the wiring?
pick-up line not in the gas?
now to state the obvious (which you have probably checked).... is there gas in the tank?
Post by: 2grand4u on December 22, 2009, 06:37:29 PM
there is a half tank and i didn`t see any pick up line but the filter is at the bottom in the gas so isn`t that were it picks up or i`m i missing something
Post by: Immortal on December 22, 2009, 06:52:53 PM
Post by: 2grand4u on December 22, 2009, 07:28:25 PM
the plug only gose in one may so the wires can`t be reversed
Post by: Immortal on December 22, 2009, 07:57:46 PM
k... hmmmmmm....
is the angle of the tank different from the original angle? Might be sloped away from the pump, thus starving the pump...
Interesting problem Ryan.
Post by: 2grand4u on December 22, 2009, 08:08:33 PM
the tank is half full so i don`t think it could be starved the tank is level, maybe i`ll throw some more gas in it and see what happens.
Post by: JackstandJohnny on December 22, 2009, 08:35:19 PM
why didn't you just put a skid plate over the gas tank and leave it?   or a 2" body lift and lift the tank 2"?  instead did you put it in the rear of the TJ, thus taking away any cargo area you may have had?
pump whirs?  filters good?
pressure in your fuel line?  so you start it and it just cranks over and over again? does it stutter? is it getting any fuel?  is it throwing any codes?  what did you do to clean the tank? the filter?  did you clean the pump?
Post by: dac on December 22, 2009, 09:44:25 PM
I could be wrong on this but when you disconnected the tank the line probably drained (now full of air).  When you turn the key, the pump should presurize the line so to speak, but if it's full of air not much will happen, pump should keep going.
Now for the dumb question.....
Have you tried cranking it with your foot on the pedal to try and bleed the air out   ???
Post by: boggincj7 on December 22, 2009, 10:21:11 PM
I think you have to prime the pump. Try disconecting the line after the pump and then try to get it to suck fuel. Once there is fuel in the line you should be good to go. My friend use to have a fuel problem on his injected 4.3 cj5. Sometimes it would lose pressure and that is how he would prime it again. Took him like 5 min. Maybe this will help you.
Post by: Bnine on December 23, 2009, 07:05:57 AM
No prime needed on those pumps. Either check the wiring, or check that you didnt brak a clip on the pump can. If you get the can cock eyed, it will cause the pump lines to seperate.
Post by: 2grand4u on December 23, 2009, 04:17:25 PM
with the fuel line off the top of the pump the pump spins but dosn`t pump fuel out, almost like the impelers are gone. i think the pump is bad, know if the pump is bad can i go to pnp and get a cherokee pump, will it work i just won`t to go wheelin on my holidays so it dosn`t half to be a permant fix.
Post by: Bnine on December 23, 2009, 07:43:05 PM
Probably not unless you can find a 97 or newer. OBD 2 stuff in TJ's runs 49 PSI, OBD 1 stuff in YJ only runs around 26 if I recall right. Xj's are probably the same.
Did you check the can or not?
Post by: comanche killer on December 24, 2009, 08:54:43 PM
I seconed this   skid plat and 2" body lift
I told u the same thing when I was there when u told me what u were doing
Post by: 2grand4u on December 25, 2009, 09:02:04 AM
because body lift are the most ugly thing you can do to a jeep, and i was trying to stay low.  there still lots of room for gear in the back.  and now when i drop in a hole i won't get winded by i huge hit when my tank hits, and it didn't cost me anything to put it back there other then finding out the pump is shot.
Post by: 4Banger_madness on December 27, 2009, 02:37:19 PM
u probably lost and o-ring or seal someplace while cleaning
Post by: WagoneerXJ on December 27, 2009, 02:48:19 PM
probably ran great before the tank was moved  :-X
Post by: esi on December 27, 2009, 03:31:50 PM
Try this but do it carefully.
If you have an air compressor.
Take blowgun, wrap a rag around the gun and stick it in the filler hole. Add air. the vent will let it out, but you only need about 10 PSI to lift fuel. See if you can get it running that way. You may have got a chunk of crap in a check valve.
Use caution and don't have any open flames near by this will push alot of vapour out of the tank.
Post by: 2grand4u on December 27, 2009, 06:39:36 PM
i'll give that a try but i'm giving jeep stuff a call towmorrow to see if i can get a pump
Post by: esi on December 27, 2009, 09:26:45 PM
Forgot to say you'll need another person.
one to add air to the tank and one to turn the key.
You'll have to keep giving it air to keep pressure in the tank since the vent line will bleed it off
Post by: 2grand4u on December 28, 2009, 06:06:22 PM
got a new pump from jeep stuff and the truck runs great, thxx for any info any of you have provided
Post by: Jeep Stuff on December 30, 2009, 04:31:07 PM
Nice.... so glad to hear its all fixed!  You should of told me you were from the Jeep Assoc and I could have given you the 10% discount.  Next time you need something I will take care of that!
