4x4 Related Groups => Tech Talk => Topic started by: Alltornup on December 09, 2010, 11:00:47 PM
So I got some new 33's on the Jeep, (i only had 30's on before) and I know I have to extend my bump stops. I have 2.5HD OME with 1" body lift on my TJ. What are you guys doing for this. I bought 2" bump stops from Modern. Is this too much or just right.
I'm not looking forward to yanking the springs out again. The first time I didn't know they were side specific and let behold all springs were in the wrong spot. lol.
And work said they would buy me a M8000 winch so should I go ahead and put a 3/4 spacer on the front cause it sits perfect right now. I think it will sit too low with that weight on the front. I don't want to pull the springs a third time if ya know what i'm saying
just slip in a hockey puck and pl-40 it
Been down that road before. Just jack the Jeep up by the frame and let the front axle droop. There should be enough space between the coils to get a hockey puck in with a little persuasion. Stack two of them in there(should be close to 2") and epoxy them together.
HTH
