4x4 Related Groups => Tech Talk => Topic started by: specialk on December 07, 2011, 12:21:50 PM
What size tubing have you used when replacing the rockers on your MJ/XJ? 2x4 or 2x6?
And do you cut out up to the pinch weld?
Cut until there isn't anymore rust. That will be enough to get a 2x6 in mine. You may be able to get away with just a 2x4, though.
And, yes.
I used .250 wall 2x6.
I only cut the outside of the stock rocker out which gives enough room to jam in a piece of 2x6 HSS with a little persuasion. The stock sheetmetal will hold the slider in place really well, then just weld 'er up and call 'er done.
Ask Dana to send you a picture of how he has just done his... His original set was flush and it didnt seem to look right... On the 2 door now he has left a lip that is welded to the 2x4 box and it looks pretty damn good.
Thank you gents.
i forget and its too far away for me to check.
what ever you can get ahold of that works, i know tootc could not find the same size as i used but his turned out great.
i think .25 wall is way over kill. mine is .125 and i have kicked the crap out of it with no dents or bends.
Its a shity job but when its done its super tuff.
Agreed. I only used 1/4" cause I was/am planning on using the sliders as air tanks once I finish my ghetto homebrew OBA and wanted some "erosion allowance"
I'm sure 0.125" would work well
