4x4 Related Groups => Tech Talk => Topic started by: el duke on December 28, 2011, 04:11:50 PM
Well i bench tested the starter,it works fine
AAm not getting any power from the ignition,
to the starter,relays are ok and fuses are ok
any suggestions?
Check your grounds as a start.
neutral safety switch?
I will check the grounds today.
This is a standar trans. so i dont think the neutral switch applies,
but thanks.
What about a clutch relay?
The last time this happened i had to replace sterring column assembly cause actuator switch was broken 1200 bucks
Neutral safety switch clutch relay same beast really but check it first they go out on occasion.
but thanks.
or you could buy the actuator switch at napa for 40 bucks.
come on just install a push button start . ;D ;D ;D
Ya i have not looked at the ignitionn yet.
Am just working on that push button start rt. now
Tried the push button start,it worked once!!!!!!!!!
Thought i had her licked.Did not work a gain.
Something must be broken in the ignition,i even moved the
20amp fuse in glove box to no avail.
Anyone else have this problem?
BEATS ME?
Finally got the jeep in the garage.
Pulled apart the ignition,and it was a broken,
ignition actuator pin.Here we go again! Part not sold seperately,
pick a part, i guess ,FRICKIN POT METAL PIECE,what challenged
idiot came up with this schematics for this
Why dont you just buy a new one instead of wasting your time like this?
Ya after all that it was the
actuator.AA piece fell off a fter disassembling
steering column,i knew that was the problem.
Thanks for all the input.
I just was not sure ;D
