4x4 Related Groups => Tech Talk => Topic started by: RookieRecurve on June 13, 2012, 09:54:42 PM
Title: Airing Down
Post by: RookieRecurve on June 13, 2012, 09:54:42 PM
Forgive me if this topic has been beaten to death.  I did a quick search and did not see any answers to my question.  It seems that "airing down" is the norm here.  So my question is this:  Does everyone on here have some kind of onboard air compressor?  How does everyone air back up when it is time to drive home?  I would prefer a less involved way to air down than having to invest in an onboard compressor.  Does an air-pig carry enough air to refill 4 tires to a suitable road pressure?  Is there a cigarette lighter powered compressor that can do an adequate job (less than an hour!)?
Title: Re: Airing Down
Post by: Anton on June 13, 2012, 10:02:48 PM
Canadian tire or wallmart has air compressors for 40-60 $. I use one of them to air up. I just did not get around to get a good one yet.
U can by good ones that just hook up to your battery and they are fast. just look up portable aircompressors. smithy build, ARB, Titan Max. There is allot of them out there. But if you want some cheap then don't be surprised if you will be spending more then 1 hr airing up all 4 of your tires.
and it is all depends how low you went with the pressure on ur tires.
Anton
Post by: JackstandJohnny on June 13, 2012, 10:03:54 PM
many people carry the ARB air compressors. they work very well. about 300$  from Stan at Northridge.
the cool kids will utilize their AC pumps to run OBA.  it is the way to go ;)
you will not find a cigarette lighter pump that will fill your tires ever, let alone an hour ;)
Post by: Kanueh on June 13, 2012, 10:17:36 PM
Canadian Tire has a dual cylinder portable compressors that connects to the battery for $50.00. It's a NASCAR compressor with a case, claims to fill a tire in 1.5 minutes. I used one the other day and it worked great.
I bought the last one and had to search like 5 locations to find it but I heard they will special order them.
Post by: WhiteOut on June 13, 2012, 10:22:26 PM
I have an ARB wired up in the back, I can fill up 4 33" tires from 12psi (what my deflators are set to) to about 35psi in about 10 minutes. The ability to idle up with a tuner is a huge help too.
I had the Canadian Tire one that plugged into the cigarette lighter, took about 20 minutes to air up the same tires from 19psi ish to 35psi.  If you want to give it a shot, you are welcome to swing by.
Post by: Spinalguy on June 13, 2012, 10:34:53 PM
i have left trails for years aired down til i got to the closest town. Bragg Creek is close...Cochrane is close, etc.
i have never debeaded, prematurely worn out tires, flatted, etc.
Post by: fug on June 13, 2012, 10:45:39 PM
In my old YJ I ran 2 of the cheapo lighter pumps at a time and while slow it did work.  I could run 4 33" tires from 8-9lbs to 25-26lbs in about 30 mins or so.    Course in my TJ I have a viair with a tank... just a wee bit faster ;)
Post by: Rubi03 jef on June 13, 2012, 10:47:47 PM
[/quote
i agree . with this guy
i used to have a warn power plant with the compressor built in and it worked pretty damn good but it finally died and i sold it
then after that . i would air down to 8 psi and run that all day drive home with that and usually back to work the next day then fill . some times i would run 8psi for weeks on end never had any issues . 35's on a jeep the tire still has plenty of air in it at 8psi .. and when i did air back up it never went over 18psi . tires always stayed round and never cupped
with a bigger rig youll want to probably stay above 12 -15 psi . and a short drive home  or to the closest gas market should be just fine
Post by: foghorn on June 13, 2012, 11:09:11 PM
My viair 400h does 4 33s from 12 to 28 in about 8 minutes or so, no tank and was 200 beans. Just need an open chuck or drill a closed chuck.
Post by: bradley on June 13, 2012, 11:32:47 PM
I took and did an on board air system with my a/c compressor I would recomend it to anyone
Post by: Rubi03 jef on June 13, 2012, 11:41:22 PM
i dont think this guy is ready to change out is AC compressor for a on board air system .. power wagon is 2 new still
Post by: bradley on June 13, 2012, 11:46:41 PM
Sorry I didn't realise he had a power wagon
Post by: RookieRecurve on June 14, 2012, 07:18:27 AM
Busted again!  Yes, the truck is too new to gut the A/C.  It is also my DD and my only vehicle so I do not want to modify it to that extent.  Thanks for the input guys.  I appreciate the sharing of knowledge despite my sad condition of not owning a Jeep anymore.  Sold my old '74 wagoneer last year when I moved across the province.  Now THAT was a Jeep!  ;)
Post by: Bnine on June 14, 2012, 09:08:35 AM
For the occasional wheeler the powertank is probably one the most versatile and relatively affordable options.
For under 400$ you can run air tools, fill tires, re-seat blown beads, fill air mattresses camping, blah blah.
A powertank will fill 33" tires from 10-30psi well over a dozen times between fills.
And at the end of the day its the fastest air you can buy. Filling 33's is only 30 seconds a tire.
Here's a link
http://powertank.com/
Post by: hps4evr on June 14, 2012, 09:54:20 AM
Here's a link
Bill makes a good point, power tank or compressor they work for anything. Portable air is handy anywhere you go. I keep my compressor with me all the time.
Post by: JohnB on June 14, 2012, 11:52:09 AM
One in every five trucks needs a York.....   ;D  Two minutes per truck.
If you do go down the low cost CT style compressor, just buy two of them as they are cheap and do 2 tires at once.
Post by: Hi Lo Silver on June 14, 2012, 02:54:45 PM
Post by: RookieRecurve on June 14, 2012, 03:49:56 PM
I think I will go with the Viair 400P.  Seems like a reasonable price, and a reputable name.  I like the idea of the powertank as it has no moving parts, but having to pay to fill the thing up all the time is less appealing.  I want free air!
Thanks all for the comments.  Definitely helped a lot.  ;D
Post by: Bnine on June 14, 2012, 04:42:40 PM
I dont know how often you wheel, but I would be surprised if you filled a powertank more then once a year.
Honestly, if you are, you need to stop wheeling that brand new truck and buy an old YJ........lol
Post by: Immortal on June 21, 2012, 11:10:12 PM
Course in my TJ .....
Pfffft, yeah right. Next thing you're going to tell us is you have a unicorn grazing away in your backyard....
Post by: specialk on June 22, 2012, 10:04:02 AM
It was not in his backyard... in was in Banff
http://www.youtube.com/watch?v=AkW-EAkClbE
Post by: esi on June 22, 2012, 02:22:06 PM
Another option you could look into is a set os that of brackets that allows you to add a second compressor, so you can keep your AC and still get OBA.
