4x4 Related Groups => Tech Talk => Topic started by: dhlo on January 07, 2014, 08:02:41 PM
Title: TJSJEEP won't turnover
Post by: dhlo on January 07, 2014, 08:02:41 PM
I'm not sure if anyone knows anything about Jeeps in this forum, but I'll ask anyway...   :D
A couple of days ago, I went to drive to the store, using the 2001 TJ for the first time in about two weeks.  It wouldn't start, just clicking.  After several tries, there was no more clicking and the voltage was really low.  Figuring because it was idle for so long, I just needed a boost.  A buddy helped me out early yesterday evening and we got it going no problem.  Let it run for a bit and hit the road to meet my buddy at Regal Beagle to reward his help with cholesterol (delicious, delicious cholesterol).  After a couple of hours of beer and wings, the TJ started again and I got home.
So, today I hoped in at 245PM to pick my Son (his name is also TJ, no relation) up from school at 3PM and I got clicking again.  403-299-1111 was immediately called and I picked him up just in time and we got home.  Had my buddy help me out with a boost again, but this time no clicking and no turnover.  All of the lights and gauges seem to work.  I did the three quick key turns for diags and it didn't return a code, just the word dONE.  I also cleaned the battery posts last night because there was some corrosion.
Any idea what's borked?  I did have a check engine recently, but I tightened the gas cap and all was well - this would happen every once in a while because the seal is looser than Paris Hilton.  About a month ago, I got the CHECK GAUGES light, but after shutting down and starting up, that went away.
Title: Re: TJSJEEP won't turnover
Post by: JackstandJohnny on January 07, 2014, 09:02:42 PM
battery!
Post by: dhlo on January 07, 2014, 09:18:16 PM
You think so?  I had a boost from the same running vehicle that tried today (failed) with the same cables and the TJ started up right away.
Maybe it's a combination of a boned battery and fried starter relay from low power the first time after two weeks?  No clicky stuff at all anymore even though the gauge during the boost showed 14V - it climbed from about 10V.
Post by: AV.NINE on January 07, 2014, 09:37:18 PM
Johnnys right, its your battery.
Go get your alternator tested as well, couldd be the reason your battery failed.
Post by: dhlo on January 07, 2014, 10:55:46 PM
Thanks Guys!  I tried a Lada forum and couldn't understand what the H377 they were saying...
I'm gonna try the following, in order of expense:  the relay, the 40A relay fuse (I haven't found it yet, but I assume that under the hood in the PDC), the battery and then the alternator test.
Hopefully something works because I'm in underground parking and tows don't dig the tight space.
Q about the alternator:  How easy is it to install?  I've done it on my CJ (totally easy), but haven't done much hands-on work with the TJ.
And, another Q:  Is it cool to spray down the engine compartment on the TJ with a power washer, of course covering any air intakes.
Post by: pooljunky on January 07, 2014, 11:14:50 PM
the battery for sure. I hose down my compartment all the time.. and I usually change my alternator between 30 minutes to an hour.
Post by: dhlo on January 07, 2014, 11:27:25 PM
The alternator is up top on the belt on the left-hand side of the compartment, right?  I used to do all of the work on my CJ (except for the steering box detaching and I could only drive right - not cool in Palliser parkade, but fortunately, the spiral out lane goes right, so I made it down to the tow truck), but the TJ compartment is more tight so I haven't paid that much attention to it.
Post by: AV.NINE on January 08, 2014, 05:55:21 AM
Buy a batt and alternator, shoot me a message 403.991.5950. I have a large garage and many tools, shouldn't take more that 30 mins to change both.
Bring some beer.
Post by: Bnine on January 08, 2014, 09:18:02 AM
For christ sakes, do yourself a favor and get volt meter. Come back and we will help you diagnose some crap.
For the regulars - you are guys are the worst armchair mechanics in the world. DIAGNOSE DIAGNOSE DIAGNOSE
God knows, not one of you cheap bastards would ever just throw parts at a problem without knowing whats busted. But everytime someone asks a question here you start grenading parts suggestions before you have a clue whats wrong.
DIAGNOSE
RECOMMEND
REPLACE
Get your crap straight if your going to help people out.
End rant. Happy new year. Love you guys
Post by: fug on January 08, 2014, 09:30:26 AM
Glad to see you're around and unchanged Bill!
I gotta agree with you.  One thing I've learned the hard way is that its better to figure out whats wrong vs. guessing and throwing parts at a problem.
DHLO:  Get a voltmeter... cheap one will do.  Measure the voltage of the battery.  If it's above 12.5V or so then the battery is not your problem.  If your battery checks out and you aren't getting any starter action.. it's time to start looking at your starter (or the wiring to it).  If thats the case... come back then and we can give you some pointers at that point.
Post by: dubbleJs on January 08, 2014, 01:09:43 PM
and did you check the gauges when it said this? I'm guessing it was your voltmeter showing somewhere around 9volts....
Post by: dhlo on January 08, 2014, 03:07:28 PM
I have a voltmeter and will give it a go tonight.  Picked up a battery, starter relay (RY612) and a 40 volt fuse.
If replacing the battery gets it running, can I also use the voltmeter on the alternator?  If so, what am I looking for?
Another thing:  When I cleaned the posts, I was able to pop off the negative (always negative first) no problem, but positive wouldn't budge.  Any suggestions on how to get it off without busting something or turning myself into Two Face?
Post by: fug on January 08, 2014, 03:21:01 PM
One of the quickest way to test your alternator is to measure voltage at the battery terminals with the car off then with it running
With it off it should be around 12.5 volts
With it running it should be up around 14ish volts
It's not an exact thing... and its still possible that you could have a bad alternator that gets bad under load... or pumps out too high a voltage at higher RPMs and fries your battery.
If you google there's tons of info on testing an alternator with a voltmeter (even some videos).
Good luck and let us know how it goes.
Post by: dhlo on January 08, 2014, 03:32:01 PM
Thanks for all the advice Guys!  I'll give it a go and let you know...
Post by: JackstandJohnny on January 08, 2014, 04:09:35 PM
perhaps i should have written more.
i meant to say to pull the battery and get it tested first at a place like Auto Value or Canadian tire. they'll usually test them for you free of charge.  (charge, get it? haha)
i'd test before installing the new one just in case.
also, if you want i have like 4 alternators kicking around. all came from ZJs. so if they work for TJ you can have one to see if that is your issue.
Post by: dhlo on January 08, 2014, 07:24:46 PM
Thanks JackstandJohnny for the offer!  I installed the new battery and she fired up like [insert nasty ex-girlfriend, current girlfriend or miserable wife metaphor here].  But, I'm keeping my eye on cold and running volts for a little while, so I might have to take you up on your offer.
My process:  Test voltage cold on old battery - ~12V.  Test when trying to start - fell down to 7V.  Installed new starter relay - no improvement.  Tried to install 40A fuse - wrong type.  Removed old battery and installed new.  Tested cold voltage - ~12.5V.  Running voltage - ~14.2.
Although, I forgot to test the running voltage with everything turned on like the heater, lights, etc.  I'll try that tomorrow because it's time for beer now.
Thanks for your help!  Yeah, it's a simple fix that I should have tried first, but why not go to the experts first...
Post by: scott slade on January 08, 2014, 07:27:48 PM
STARTER...!!!!!!!   ;D
Post by: AV.NINE on January 08, 2014, 09:09:21 PM
DIAGNOSE
RECOMMEND
REPLACE
Sorry Bill, but blatantly obvious battery issue.
The real question is why did the battery fail? age, alternator, bad grounds, bad wiring, frozen, etc.... hence the reason i said to test the alternator. But the fact the vehicle only started when being boosted pointed to the battery itself being the issue.
K.I.S.S. rule buddy!
Post by: dhlo on January 08, 2014, 09:44:06 PM
I agree with using my voltmeter, but I wanted to get broad (hehe) input on a broad (hehe) problem.
And, I agree with trying to figure out the cause of the failure.  It was about a 5y old battery, had to get it boosted a couple of times over the last couple of summers because the doors were off, the door fuse was pulled and I installed high intensity headlights and left them on (dead in hours), had been sitting idle for two weeks over Xmas (underground parking, so freezing is not possible) and had been sitting for a week earlier for a week.  The first boost worked, but second didn't (maybe a bad connection).
Ultimately, I think that it was a doomed battery.  But, I'll be testing with a voltmeter every couple of days for a while idle and running to look for any significant change in results that might lead to wiring or the alternator.  Plus, I'm gonna give the engine and undercarriage a good stray to get rid of the salt and crap.  Clean her up because she's dirty...
Post by: Bnine on January 09, 2014, 08:07:35 AM
Keeping it simple is testing your crap before you buy parts. Period.
