		4x4 Related Groups => General Talk => Topic started by: KorzaXJ on May 27, 2014, 01:11:42 PM
				I have pretty much ZERO articulation. I could remove the front sway bar, that should help a bit, but I flex like a neon haha
 https://www.youtube.com/watch?v=aqVdBnC3WOA&feature=youtu.be
				Ouch, that is stiff.  What springs do you have?
				Definitely disconnecting the front sway bar would help!
 Also, if you have a rear sway bar, remove it completely.
 And whatever you do, don't do this:
 http://www.youtube.com/watch?v=lDlQPnyJ42s
				And don't forget to put it in park!
				That's most certainly a sway bar  in the front. Pop that sucker and waaay different. The rear?? Do xjs have a swaybar in the rear??
 Sent from my Nexus 5 using Tapatalk
				Yes there is a rear swar bar on an xj. Known issue with a lift and rear sway at flex is end of sway bar pokes out the sidewall of your tire.
				Dang! That is mighty tippy... better get yourself some disconnects  ;)
 That happened to me after hours of working on it. I just gave up threw the spare on and got new tires the next thursday. I need swaybar disconnects pretty badly
				x2
 remove rear sway bar completely, 31 inch tires stuff well in the rear fenders
				there is no rear sway bar, I (at first) disconnected it, then something happened and it ended up exploding my rear tire, and snapping in two
 (http://forum.calgaryjeep.com/gallery/1/7760_28_05_14_9_07_52.jpg)
 also when i say something happened i meant, "something happened" haha. typical little whoops moment
