Author Topic: weekend project  (Read 3066 times)
Offline Rookie
weekend project
« on: September 01, 2008, 09:50:15 PM »
I got fed up with this
So I built this
TJ with some stuff
TheCaptain
Re: weekend project
« Reply #1 on: September 01, 2008, 10:45:58 PM »
Nice work!!
What did you use for the project?
RUBI
Re: weekend project
« Reply #2 on: September 02, 2008, 11:08:38 AM »
How much of a body lift are you running Steve ?? I did the same thing , 2" body lift and a 1-1/4" drop on the belly pan.....now I'm waiting for my short arms so I can correct the pinion angle........Mine is outta 1/4" Stainless Steel Plate !!!
Offline Rookie
Re: weekend project
« Reply #3 on: September 02, 2008, 08:21:46 PM »
Nice work!!
Metal ::)
Just Kidding   :D
1/4" plate ,some angle Iron ,some bolts, some welding and a whole lot of measuring :)
TJ with some stuff
Offline Rookie
Re: weekend project
« Reply #4 on: September 02, 2008, 08:28:39 PM »
Darcy
I have a 2" body lift 1/4" plate
I have the advanced adapters Sye but it looks like I'm gonna have to change it to a super short sye to get the drive shaft angles under control  :-\
Or maybe this is the excuse I need to do a rear stretch  ;)
TJ with some stuff
RUBI
Re: weekend project
« Reply #5 on: September 02, 2008, 09:42:39 PM »
Must be the difference in the T-Case then..... I could not raise mine any higher without having to pound out the floorpan, and also the extreme angle of the pinion. I used a Tom Woods drive shaft with the Rubicon adapter flange, and still need the adjustable arms to correct the pinion angle at the diff.
Offline Rookie
Re: weekend project
« Reply #6 on: September 02, 2008, 10:31:45 PM »
Darcy
I forgot to mention I raised the engine 2 " as well
I have adjustable arms so the pinions a non issue for me its the angle @ the cv thats extreme
TJ with some stuff
RUBI
Re: weekend project
« Reply #7 on: September 03, 2008, 05:38:51 AM »
Did you go with 1" higher motor mounts to help eliminate some of the angle at the SYE ????
Offline Rookie
Re: weekend project
« Reply #8 on: September 03, 2008, 06:44:48 AM »
I rasied the motor mounts 2"
TJ with some stuff
Offline Joel
  • Super Uber Web Wheeler
Re: weekend project
« Reply #9 on: September 03, 2008, 08:49:23 AM »
That looks good Steve,  amazing how much clearance you have.
RUBI
Re: weekend project
« Reply #10 on: September 03, 2008, 10:36:28 AM »
2"  :o  You must of had to make some changes to the fan shroud then as well............I only went with 1" myself. ;)
yjcanibul
Re: weekend project
« Reply #11 on: September 03, 2008, 08:34:43 PM »
Metal ::)
they are impressive builds ,  like getting an additional lift installed , I just learned plastic skids are out there in various new vehicles, I'd go tried/true metal too ...
