Author Topic: Thermostat Gasket - Not listed!? 2004 Rubicon  (Read 1065 times)
Offline Tinkerer
    • My (OLD OLD OLD) website
« on: September 25, 2008, 06:34:34 PM »
I went to two vendors, one of which I usually find pretty reasonable, but both of their systems said that there was no gasket listed for a 2004 Rubicon with 4.0L inline 6!  They had thermostats... they seemed to think that the thermostat for a Rubicon is different than that for a non-Rubicon, which I sincerely doubt. The Stant website doesn't distinguish between the two at all.
Any ideas? If I can avoid using "make a gasket" as the sole gasketing material or cutting my own from bulk material (if I can find it in my garage), I'd prefer that.
PS: This is coming up because two mechanics have suggested that my random overheating symptoms are most likely due to a sticking thermostat.  I have burped the system and done all kinds of other testing etc. and just sometimes while cruising at a constant speed on a flat portion, suddenly it will overheat, then cool back to normal again almost instantly.  Electric fan, which has been working properly etc.
Thanks!
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
Offline Waytec
  • not all there
Re: Thermostat Gasket - Not listed!? 2004 Rubicon
« Reply #1 on: September 25, 2008, 06:45:41 PM »
Have you tried a Jeep dealer yet? If they cant find it, it is not their.
The obstacle is the path.
« Reply #2 on: September 25, 2008, 06:46:33 PM »
dealership should have it
yjcanibul
« Reply #3 on: September 25, 2008, 07:20:21 PM »
you mean thermostat housing gasket ?
yjcanibul
« Reply #4 on: September 25, 2008, 07:50:19 PM »
dealer will do you right, the parts guys are probably just confused - tell 'em its an '04 tj 4L and they probably got one under the counter ...
on the subject of dealers ( which has a inherit bad rap from the '60s man  ::) ) ,  in the times I have compared prices they are very competitive least 1/2 the time ... and next day delivery is always an consideraton for those times when you feel gouged ...
« Reply #5 on: September 26, 2008, 08:18:17 AM »
I installed one of those thermostats and it help with cooling, http://www.hesco.us/shop.asp?action=details&inventoryID=43014&catId=7969.  I got it at Mopac for like $15.
« Reply #6 on: September 26, 2008, 08:29:59 AM »
Same gasket all over Pat. The parts stores just dont go up to 04.
Offline 4PLAYZJ
« Reply #7 on: September 26, 2008, 08:45:23 AM »
A proper gasket is good but there is nothing wrong with a silicon gasket there.  Just use a good quality silicon like permatex ultra grey.
