Author Topic: Getting a lift  (Read 2019 times)
Katt
Getting a lift
« on: October 10, 2008, 09:02:18 AM »
I'm putting a 3'' body lift on my '03 TJ, and I'm getting 15X8 off set rims. I'm wondering if I have other options for bigger or beafier tires. Any opinions are much appreciated. I'm new to all this and am not sure which way to go here.
Re: Getting a lift
« Reply #1 on: October 10, 2008, 09:43:01 AM »
dont go with only body lift .. u might want to go with some suspension and body
Re: Getting a lift
« Reply #2 on: October 10, 2008, 11:22:31 AM »
I'm not an expert with TJs but I know that 3" body lift is not the greatest ...  Why are you going with a 3" body lift?
I don't understand your question also...  Do you want to know what size tire you can fit with that Lift?  or you want to know what's a good tough tire?
let us know what you wnat to do with your Jeep...
Katt
Re: Getting a lift
« Reply #3 on: October 23, 2008, 03:21:55 PM »
I've done the 3" body lift and went with 31X10.5. Now I'm looking at a 4" suspension lift to go with it. Wondering about the axles after I do this. Excited but scared about it. What do you think?
« Last Edit: October 23, 2008, 03:25:15 PM by Katt »
Re: Getting a lift
« Reply #4 on: October 23, 2008, 03:36:06 PM »
7" of lift and 31s will not be the best for stability, it will be quite tippy.  As for axles it all depends on what size tires you want to go with and what axles you currently have.  Your questions can't be accurately answer until we know this.
Offline JasonL_031
    • http://www.cardomain.com/ride/2449290
Re: Getting a lift
« Reply #5 on: October 23, 2008, 05:30:19 PM »
wow i did 2 and 2 with my old jeep tj and i cleared 33s with no problem
1994 ZJ
6.5 inch custom lift
5.2L v8 with 5.9 exhaust
35x12.5r15 beadlocks
custom front bumper
98 leather interior
rugged ridge steering conversion
np231 tcase swap
HIDs
LED off road lights
Offline barmanjay
Re: Getting a lift
« Reply #6 on: October 23, 2008, 09:31:24 PM »
What about drive shaft length? angle?
when I did 4" springs on my yj,.. I had to make a new rear DS and clock my axle up + 1" t-case drop
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline RedApe
    • http://www.island4x4.com
Re: Getting a lift
« Reply #7 on: October 26, 2008, 09:42:20 AM »
My $0.32, FWIW.
Things you will likely need to do, assuming you move forward with your plan above.
Body lift:
  - fan shroud clearance issues, expect to modify
  - Tcase linkage alignment...expect to either replace linkage with aftermarket adaptor, OR crawl underneath the Jeep to shift. About $50  (I've done both  ;D )
Coils 3"+ :
  - for comfort and usability, plan on SYE and a new rear driveshaft.  $600+ to your current plans
Tires...I would recommend 31", unless you plan to regear.  We run 33's, and 4.10's, and dream of 4.88.  Yes, it will be driveable, but you'll likely not be happy with it either in town or on the highway.
Keith <aka RedApe>
94 XJ <his>
97 TJ <hers>
Four Wheel Stampeders member
Re: Getting a lift
« Reply #8 on: October 26, 2008, 10:44:17 AM »
i would personally ditch the body lift and do a 4 inch suspension lift.  they can be found relatively cheap and are straight forward to install.  with that you can run a 33 inch tire, and there are many used sets around that would fit your rims. as far as axles go, you probably have a D3o front and D35 rear.  if you stick to a 33 inch tire you should be fine. will be a little luggish on the highway and stuff, but overall still driveable, and unlessl you drive like you hate your jeep you shouldn`t break anything.
or just keep the body lift and run 33s. my buddy does that. he hates the body lift though.
just to reiterate what others are saying on here..... if u go bigger than 4 inches of lift and 33 inch tires get ready to break the bank. welcome to the `jeep`thing
Re: Getting a lift
« Reply #9 on: October 26, 2008, 08:15:24 PM »
Ditch the body lift and do a 3" or 4" suspension lift and go with eithert 31" or 32" tires.  I'll assume a D35/30 combo with stock gearing (3.07 or 3.55), 33" tires would be borderline on driveability.  If you check out the TJ section of jeepforum.com, there are a lot of guys there who have one exactly what you want to do.
« Last Edit: October 27, 2008, 12:25:53 AM by fraserb1986 »
Offline Asia
Re: Getting a lift
« Reply #10 on: October 26, 2008, 11:16:06 PM »
I have a YJ running a 2.5" lift and 31" M/Ts, 2.5L angry squirrel motor and stock 4.10 gearing.  It's a dog on the highway, terrible on steep hills (3rd gear) and fine off road.  The small lift is enough, keeps the center of gravity low and the costs down.
near stock advocate
Re: Getting a lift
« Reply #11 on: October 27, 2008, 06:32:06 PM »
im looking to just throw on a 2.5 suspention lift and 33's   any one think i should just wait and go to 4.5 and 33's
i have a rubicon will i need a SYE right away
