Author Topic: HELP  (Read 864 times)
Offline JasonL_031
    • http://www.cardomain.com/ride/2449290
HELP
« on: October 10, 2008, 09:29:36 PM »
ok i am in serious need of help i installed a new starter on my jeep 4l and it is still not starting. the starter isnt even engaging or moving when i turn the key. any tips would be amazing i am so fumed off at the jeep. please help
1994 ZJ
6.5 inch custom lift
5.2L v8 with 5.9 exhaust
35x12.5r15 beadlocks
custom front bumper
98 leather interior
rugged ridge steering conversion
np231 tcase swap
HIDs
LED off road lights
Offline barmanjay
Re: HELP
« Reply #1 on: October 10, 2008, 10:50:08 PM »
clutch safety?
battery?
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline JasonL_031
Re: HELP
« Reply #2 on: October 11, 2008, 09:07:15 AM »
battery good clutch safty disconnected :@
1994 ZJ
custom front bumper
98 leather interior
np231 tcase swap
HIDs
LED off road lights
Offline fug
  • Airdrie Pick n Pull
Re: HELP
« Reply #3 on: October 11, 2008, 09:19:00 AM »
Did you replace the starter because of a no start condition?  In other words did the old starter work from time to time or did it stop starting and you replaced the starter thinking that was the problem?
I would check
- starter itself (Try jumping/hotwiring the starter... if it starts... its not the starter)
- battery cables (do the dash lights dim right down when you turn the key.. if so ... you may have a battery problem)
- neutral safety switch (sometimes you can fudge this by pushing slightly on the gear lever while you try to start... if that works... you have bad switch)
- key switch (I have a 95 with a bad switch... if you jiggle the colum wires around it will start at times)
I know what  you mean about being fumed at the jeep... at least once in a project I swear I'm going to push mine into the alley and burn it.  Keep patient and work your way through things logically and you'll get it figured out.
Fug
TJ Rubicon
Offline JasonL_031
Re: HELP
« Reply #4 on: October 11, 2008, 03:53:18 PM »
Well great news the jeep is running again.  just had to work on the ground for the starter now she fires up all the time :D and my oil pressure problem seems to be gone :D
1994 ZJ
custom front bumper
98 leather interior
np231 tcase swap
HIDs
LED off road lights
