Author Topic: Auto locker up front, winter driving?  (Read 1774 times)
Offline Canuck Bob
« on: October 15, 2008, 01:06:03 PM »
I was wondering if those who have actually driven a TJ with an auto front locker could answer a quick question?  Please be aware that I have searched this extensively and understand the full implications of an auto locker while in 4wd.  I've found that a number of people who actually drive in winter conditions with a front auto locker often have no complaints and recommend the upgrade.
How did your Jeep drive with the front locker in 4wd during the winter?  Of course, I drive 2wd most of the time and have the Dana 44 Traclok for a rear diff..
How did your Jeep drive with the locker in 2wd during the winter?
Bob
Offline XJwrencher
  • Pavement Princess
Re: Auto locker up front, winter driving?
« Reply #1 on: October 15, 2008, 05:49:14 PM »
Cant even notice it in 2wd other than noise in tight turns but its typical "lunchbox"  noise.
94 XJ with tires and sausage to make it go off roading
Offline Canuck Bob
« Reply #2 on: October 16, 2008, 06:09:16 PM »
Quick bump for a second try.
Offline dac
« Reply #3 on: October 16, 2008, 07:49:42 PM »
Would it be safe to assume they'd respond the same way as say a detroit, ie not good for daily driver?
Offline cablesmurf
  • Relapsed Jeep Addict
« Reply #4 on: October 19, 2008, 08:50:56 AM »
Fine in 2wd...but it renders your 4wd useless in the city. In 4wd and winter streets, you can't turn...your jeep will keep going straight if you are on the throttle slightest bit. Not safe IMHO. Now, I know what you are thinking...I'll just stay off the throttle around corners..but It doesn't always work out that way.
HeadHunter
« Reply #5 on: October 19, 2008, 01:48:43 PM »
I run an open front and have an auto locker rear I installed right before winter ended last year. We got one LARGE dump in town before spring hit so I took it out on the un-plowed streets for a test run... 6" of snow at least and the Jeep just went straight even from a dead stop.... well it pushed straight and made for a extremely wide semi-truck turn... I plan on putting in a selectable front locker for this very reason or else I'd go with another auto locker up front cause they're cheap and they work awesome.
Offline rws
  • Stump Grinder
« Reply #6 on: October 20, 2008, 08:43:42 AM »
I have auto lockers in both front and rear of my jeep.  Works great for deep snow but for an icy street it is not safe.
