Author Topic: Anyone have 2.5 starter noise  (Read 871 times)
Offline canfourjeep
« on: October 22, 2008, 06:24:00 PM »
I have a 95 2.5 with an AX5 transmission.  I changed the transmission and removed the starter.  When I put it back together the starter makes a loud squealing noise while starting.  I used the same bell housing so there should be no difference.  Any ideas?
stoggy97tj
Re: Anyone have 2.5 starter noise
« Reply #1 on: October 24, 2008, 09:43:01 PM »
mine does it when its cold out i know what you are talking about.  After it warms up it starts with no squeal.  Im all stock parts no change outs but nothing has happened yet.  I wouldnt worry about it yet
Offline canfourjeep
« Reply #2 on: October 25, 2008, 02:38:24 PM »
Mine makes noise every time whether cold or hot
Offline red95jeepyj
  • my jeep
« Reply #3 on: November 02, 2008, 02:05:35 PM »
you probably got some grits and or water in it i have the same problem is your starter shaft with the sprocket on it that turns your fly wheel i tryed putting a lil lub on it which works for a lil bit then does it again and or your starters going i have been through 2 starters in two different jeep yjs with the same motors
Offline canfourjeep
« Reply #4 on: November 03, 2008, 08:22:17 AM »
I just had it rebuilt and it still does it.
