Author Topic: Turn signal switch in a TJ  (Read 1497 times)
Offline WagoneerXJ
  • Bagon Wagon!
« on: October 29, 2008, 06:07:06 PM »
GF just picked up a 97 TJ. Signal lights were intermittent and then quit working altogether. You could make the left one work sometimes if you pulled the stick down a little ways. I ordered a new switch for it.
 Anyone ever changed one of these? Pain in the arse? I believe it's the same procedure for 97-01 XJ's.
84 Mustang GT-Built 351W 5spd
Offline Tinkerer
    • My (OLD OLD OLD) website
Re: Turn signal switch in a TJ
« Reply #1 on: October 29, 2008, 06:23:13 PM »
Just be really careful around the airbag!!!!
Mine is an '04 FSM, so I'm not sure.
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #2 on: October 31, 2008, 05:01:17 PM »
Got it done, easy as pie. Took maybe 15 minutes.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #3 on: November 08, 2008, 09:59:56 AM »
Mine's been getting intermittent and seems to be affected by playing with the lever.  What was involved in changing it out?  How much was the switch?  I am due to change mine before it gets to be gone all together.
98 TJ 4" lift + goodies
Offline Marco
« Reply #4 on: November 08, 2008, 05:10:44 PM »
yes i would like to know also,i turn my left signal on and wipers come on too!!! lol.
locked and loaded
Offline RckyMtnTJ
« Reply #5 on: January 12, 2009, 11:12:21 PM »
Marco,
My hazards and signal lights aren't working properly.  I pulled the combination flasher located just on the right side of the steering column.  I will swap it out in the next day or two and let you know if that was it.  It is $22 at Auto Value.  I haven't checked out Crappy Tire yet.  Auto Value tells me there are two of them, and it depends which one I am changing. From the FSM, I only see one, and I think they are mistaken.
Jeff
Offline RckyMtnTJ
« Reply #6 on: January 13, 2009, 04:34:24 PM »
Canadian Tire had a better price for the combination flasher.  I went down to pick it up, and apparently it was something different they were quoting me.  In the mean time, I put my old one back in, and it seems to be working fine now.  Maybe it was loose, or maybe I am just lucky for now.  For now I am going to leave changing out the "Combination Flasher" for another time.  ie wait and see if it acts up again.
