Author Topic: is it possible to rebuild an internal clutch slave cylinder?  (Read 900 times)
Offline bdron
« on: November 09, 2008, 07:51:30 PM »
When I pulled the old one out it had 2 o-rings in each of the 2 lines that are attached. the o-rings fell out and I put them back in. I thought if I had new ones that it might be all that it needs. Any ideas? I found out that they want $180.00 for a new one.
Re: is it possible to rebuild an internal clutch slave cylinder?
« Reply #1 on: November 10, 2008, 01:23:28 AM »
Spend the other 100$ or so and do the whole clutch while you have everything apart.
Unless you like pulling the tranny, I would just put new parts in there.
« Reply #2 on: November 10, 2008, 06:11:42 PM »
convert to external slave if you can...
