Author Topic: 2 Dr Cherokee vs Comanche Doors,..  (Read 1014 times)
Offline JENSSEN
    • Racing For The Cure
« on: November 09, 2008, 08:26:12 PM »
Are they interchangeable?
www.racingforthecure.ca
Offline Gearhead
Re: 2 Dr Cherokee vs Comanche Doors,..
« Reply #1 on: November 09, 2008, 08:34:14 PM »
As far as I know , four door XJ doors are the same as MJ doors.
Tape measure would confirm .
One of these days , I'd like to fix up my dd Comanche , doors are on the need replacing list.
Reality is , it will probably get run into the ground.
Offline JENSSEN
« Reply #2 on: November 09, 2008, 08:47:35 PM »
Oddd I thought it was 2 Dr ones that swapped in to a Comanche,.. Got measurements on your doors? I have 2 Dr XJ and 4 Door XJ doors here,... FAQ on swap parts maybe,..
Offline stroker sahara
« Reply #3 on: November 10, 2008, 06:25:48 AM »
2dr XJ doors are +/- 9" longer than 4dr XJ and MJ doors. I have seen a pic of an MJ that had extensive sugrery done to the cab to swap to 2dr XJ doors. Not sure yet if I liked it, but it sure was different.
