Author Topic: Engine Rebuild  (Read 2394 times)
Offline Waytec
  • not all there
Engine Rebuild
« on: November 11, 2008, 07:37:10 PM »
I am thinking about tearing down and rebuilding my engine 4.0L HO in a Cherokee this winter. I am consuming some oil and have over 300,000 km on it. I have read a lot on Scott's thread about cams but I am also thinking about stroking it as well. Jeff I think you stroked your 4.0L. Did you use a kit or assembled the parts that worked the best. I am looking for feed back on what has been done. I am also considering a super charger or a turbo but not sure if I will get the best bang for my buck.
The obstacle is the path.
Re: Engine Rebuild
« Reply #1 on: November 11, 2008, 08:59:50 PM »
oh, Lord...
wait until it is really broken you nit-wit....
Re: Engine Rebuild
« Reply #2 on: November 11, 2008, 09:15:32 PM »
if you have the time, place, and money then an engine re-build and upgrade will be perfect. Jeff(gearhead) knows what the details of the stroker and head porting stuff. for the wheeling you do aaron i think hold off on the turbo or supercharger. rebuild and/or stroke the engine first. adding boost is not a cheap option, especially in kit form. i think the kits were hovering around 4-5ooo$ to start.
what year is your cherokee again?
Offline Waytec
  • not all there
Re: Engine Rebuild
« Reply #3 on: November 11, 2008, 10:00:54 PM »
I have a 95 Cherokee.
I did not know the price on the turbos or SC. If they are that much forget it.  :)For Now ;)
Offline Gearhead
Re: Engine Rebuild
« Reply #4 on: November 12, 2008, 06:27:05 PM »
95 XJ , obd 1  right ?   ,  if so  , is a good thing.
Assuming the engine is stock and never been apart you're probably going to have the block bored +.030" (or more ) , due to milage / wear. The bores will be neither straight or round.   The crank will not be an issue , it gets ditched , the rods too , depending on whether you choose to go with custom pistons or not.
You will need a 4.2 donor to get a crank and rods. there are variations on these.
There is a wealth of information to read on this subject , some good , some not , I did plenty of research before begining .
Don't be fooled into thinking this is cheap , any engine build , when done right and thoroughly is not cheap , there are a few additional steps / expenses when building a stroker , adding to the overall cost.
Offline Waytec
  • not all there
Re: Engine Rebuild
« Reply #5 on: November 14, 2008, 12:05:42 AM »
I have been thinking about it. I am wondering if I should just pull it apart bore it, to true the cylinders and then put it back to gather with a high flow head and a more aggressive cam. Leave the bottom end alone, replacing what is needed. I don’t plan on going past 33’s for tiers.
« Last Edit: November 14, 2008, 06:32:38 AM by 01sahara »
Offline newfie
  • newbie and loven it
Re: Engine Rebuild
« Reply #6 on: November 14, 2008, 04:52:47 PM »
Just throwing this out there
why not just buy a crate engine, you can get one for 4-5000$ out of the states can't ya?
just a question , was thinking of doing mine when it blows apart
newfies are everywhere
Offline Gearhead
Re: Engine Rebuild
« Reply #7 on: November 14, 2008, 08:12:44 PM »
Think about it , what kind of shape are your rod and main bearings ? , your oil pump ? , timing chain ? , cam bearings ? , to avoid inspecting any of this would be foolish after 300,000 km . Are the bearing journals still round or straight ?
Food for thought , my 88 came with a 4.2 , an engine that shares many design elements as the 4.0 l that replaces it , the 4.0 is based on the old 4.2 , with some tweaks to gain torque  / HP , fuel economy and extend the production life of the inline six. Once my 4.7 was built and ready to install , I pulled  into the shop and yanked the 4.2 , followed by a teardown / autopsy of sorts.  What I found was a surprise . This engine had 260,000 km on it , had what appeared to be healthy oil pressure , no abnormal sounds and was running as well as an 80's carbed could. As long as I have owned it,  it had regular maintenance and service.  The rod and main bearings had very little babbit left , mostly copper plating showing , the cam bearings were shot , a couple of them fell out of thier bores when I pulled the cam out . I had replaced the timing chain once and a few gaskets , other than that the engine was untouched. The oil pumps in these engines are known to have a service life of 150,000 miles .
When you are ready  we'll talk some more , I'm equipped to inspect , measure down to .0001" , and evaluate what you have .
Oh , if this engine has ever been overheated real bad  or swamped , there's potential for unseen issues that are not obvious till  , it comes apart for inspection.  Don't buy any hard parts till you know what size everything  is , only then can you make a shopping list. Believe it or not there are blocks  as delivered from the factory that can have more than one size of piston ! ,  mass produced variances are a reality in manufacturing , machining tolerances vary wildly too.
Re: Engine Rebuild
« Reply #8 on: November 14, 2008, 08:44:26 PM »
WOW!! Good to know Gearhead...
I have a 97 XJ 4.0L with close to 400k on it (odometer says 390k, but bigger tires throws that off a bit.) The engine is still running strong, as far as I know. After reading that.... maybe not so much.
Offline Waytec
  • not all there
Re: Engine Rebuild
« Reply #9 on: November 14, 2008, 11:53:05 PM »
Gearhead where would be a good place to start looking for engine parts. I mean everything for a worse case scenario. I need a ball park on prices. I am really thinking that I should tear this down and rebuild it. It has 300 000 plus and I don’t think it has ever been touched. I will be going to Mopac on Saturday because they are up the road from me and I like looking around in their.
Offline Gearhead
Re: Engine Rebuild
« Reply #10 on: November 15, 2008, 12:12:52 PM »
A suggestion , I've done this several times .....................
Find a core to rebuild , in the mean time you can still drive your vehicle.
Tear down the core and inspect , make a plan based on the condition of your block , crank etc. .   When I do a rebuild , I buy all of my parts from the machine shop that is preparing my block n' stuff.  They supply the pistons rings , gaskets , oil pump , cam , lifters , timing chain / sprockets , pushrods , rocker arms and so on , in kit form  .    I do the assembly , they hot tank the block and head , check for cracks , bore the cylinders , align hone the main bearing bores , install the cam bearings and freeze plugs , size the rods , grind and polish the crank.  I do the disassembly and preliminary inspection , then drop off the parts needing machining , such as the block ,crank n'rods , cylinder head and so on . Any thing thats not useable goes in the garbage , the machine shop needn't see any of the the stuff that will be discarded ,  only the items that they will be working with .  They will draw up a work order and begin the process , at that time I advise them of the other parts I will be needing to finish up building the engine  and request that they be ordered. When the machining is done , the rest of the parts order should be there and ready for pick up at the same time .
some prices..............
Hot tank block and head                                            $60
Bore 6 holes        $150
Deck block        $130
Resurface cylinder head                                            $75
Supply & Install cam bearings & frost plugs       $120
Align hone  main bearing saddles                          $185
Supply pistons                                                              $285
Arp rod bolts        $90
Rings        $105
Balance crank , rods , pistons ( stroker )               $300
Grind crank        $210
OIL pump        $114
Rocker arms        $84
Push rods        $48
Gaskets        $150
Rod bearings        $52
Main bearings        $115
There's going to be some other expenses as well , water pump , hoses , thermostat , paint , doe's it need a harmonic balancer ? , tune up parts , how's the clutch ? , is the radiator  any good ? , and so on ...................... plan for addtional costs  and do not cheap out or overlook any thing that may contribute to early failure  or damage to your newly rebuilt  engine.
Re: Engine Rebuild
« Reply #11 on: November 15, 2008, 01:14:07 PM »
Follow everything Jeff says.
Hesco is a good place to shop for some parts and get ideas on cost.
I recommend Keith Black for pistons if you go stroker. He does custom pin heights which allows you to retain your 4.0 rods. Makes a little more hp due to less angle applied to the roatating assembly.
Those pistons are 100$ a hole.
I'd recommend staying away from superchargers and turbo's at this time, unless you are willing to become a motor expert of your own.
Offline Gearhead
Re: Engine Rebuild
« Reply #12 on: November 15, 2008, 02:26:55 PM »
An observant person   should notice , there are no prices or mention of cylinderhead work.  That would be an additional expense and varies  , .depending on what is done with the cylinder head.
I generally will not touch a cylinder head until it's been checked to see if it's straight , has been hot tanked and checked for cracks. A cracked head is of little use so no time is wasted messing with it till cleaned and inspected.
