Author Topic: block heater?  (Read 1775 times)
superspud
block heater?
« on: December 02, 2008, 10:04:22 AM »
hey, how do you install a block heater? simple as draining the coolent then putting it in? how do you get the freeze plug out?
for a 95 yj 2.5 l
thanks
Shane
Re: block heater?
« Reply #1 on: December 02, 2008, 10:13:01 AM »
pry the frost plug out with a flat screw driver.  i've hammered a screwdriver into it and then pried it out.
if you open the tabs on the block heater and have it ready, you can quickly put it in while only losing a litre or two of fluid.  just leave the rad cap on so it drains slower.
just have to have something to catch the fluid
superspud
Re: block heater?
« Reply #2 on: December 03, 2008, 08:55:05 AM »
thanks man
really, just pry it out? is it really stuck in there?
Offline XJHERO
  • Soberphobic
Re: block heater?
« Reply #3 on: December 04, 2008, 09:47:35 AM »
thanks man
yup
it goes in a Frost plug hole so iff your coolant was to freeze it would just push it out befor the blok craks.
or sumthin like that. ;D
DD
Get at me Wolf
Offline JENSSEN
    • Racing For The Cure
Re: block heater?
« Reply #4 on: December 04, 2008, 12:45:00 PM »
OK maybe I am the only one who likes the coolant heat pumps,.. screw trying to get the frost plug out,.. cut your rad hose put it in line and heat the whole engine and not just one spot,...
Just my 2 Cents
www.racingforthecure.ca
superspud
Re: block heater?
« Reply #5 on: December 04, 2008, 11:59:36 PM »
good point, but im a broke arse student.
how much do those run?
Offline JENSSEN
Re: block heater?
« Reply #6 on: December 05, 2008, 08:34:46 AM »
$50-60 + 2 hose clamps, and a splash of coolant
