Author Topic: Body Lift installation, 97 TJ  (Read 1338 times)
Offline WagoneerXJ
  • Bagon Wagon!
« on: December 20, 2008, 04:22:29 PM »
In the next few weeks I will be installing a 2" body lift on my girlfriend's 97 TJ Sport, 4.0 5spd. Now I bought the body lift used,it has the blocks and body bolts.
 Is there anything else I will need to install it? I've done body lifts on fullsize trucks and there were things like steering shaft extensions, fan shroud brackets and things like that. Will I need any of this for the TJ? Thanks!
84 Mustang GT-Built 351W 5spd
Offline sylvrinvader
  • the micro wheeler
Re: Body Lift installation, 97 TJ
« Reply #1 on: December 20, 2008, 05:53:29 PM »
when i do my bl im also doing the motor mounts
Offline TJ54
« Reply #2 on: December 20, 2008, 05:53:43 PM »
the fan shroud will have to move, maybe the whole rad moves a little, I can't remember 'cause i put on an electric fan. An extension for the fuel filler tube, bracket for the t-case shifter.
I ended up taking it the body lift off, I found that with 31's the 2" suspension lift was more than enough. What size tires are you planning on going too?
Offline TJ54
« Reply #3 on: December 20, 2008, 05:57:04 PM »
If you are doing the body lift and  lifting the engine, and are  still using the stock fan and shroud you may need to be creative so that the fan does hit the shroud. Unless, of course the bl and motor mounts have the same amount of lift
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #4 on: December 20, 2008, 07:13:15 PM »
The goal is to run 33's on this TJ. Was going to add a 2" Budget Boost later on. I can mess with the fan shroud easily I think, but the fuel filler tube and t-case shifter parts didn't come with the body lift. Can I buy these seperately anywhere?
  • the micro wheeler
« Reply #5 on: December 20, 2008, 07:19:45 PM »
i just did 2" spacers on mine for the 33's and i have no probs and i bet its a lot easier and cheaper to do then a bl
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #6 on: December 22, 2008, 12:27:33 PM »
I didn't know you could fit 33's with a 2" lift, on a TJ. That's why I was going to do the 2" BL and a 2" Spacer Lift.
  • the micro wheeler
« Reply #7 on: December 22, 2008, 05:37:08 PM »
i have had no rubbing what so ever
