Author Topic: Transmission, Tranfer case and Differential fluids  (Read 1090 times)
TheCaptain
« on: January 08, 2009, 01:48:47 PM »
If I were to walk into Canadian Tire tonight, what would be the best stuff to pick up for changing all three?
I am on a mission to get it all done tonight after a stop on the way home after work.  8)
*Also as a side note, what colour RTV gasket sealant doyou guys use for the diffs?
Re: Transmission, Tranfer case and Differential fluids
« Reply #1 on: January 08, 2009, 01:50:13 PM »
I believe it is ultra black or something
Offline rws
  • Stump Grinder
« Reply #2 on: January 08, 2009, 01:58:43 PM »
I have used the Permatex Ultra Black or the Blue gasket maker, both work good.  Be aware that some "full synthetic" gear oils will EAT silicon gasket making compounds.
TheCaptain
« Reply #3 on: January 08, 2009, 01:59:40 PM »
Holy...  :o
TheCaptain
« Reply #4 on: January 08, 2009, 06:38:47 PM »
Anyone?
Offline fug
  • Airdrie Pick n Pull
« Reply #5 on: January 08, 2009, 10:01:59 PM »
231 Tcase is ATF+3
nv3550 is Snychromax or the mopar fluid (good luck finding it at Can Tire Tho)
Diffs are 80W-90
Fug
TJ Rubicon
superspud
« Reply #6 on: January 11, 2009, 05:31:47 PM »
i have the same question.
i heard redline mt is the best for tranny but i cant find it. do i have to go to mopar?
what is the best to use that can be found local for a reasonable price..?
Offline dac
« Reply #7 on: January 11, 2009, 06:34:42 PM »
ATF 4 for the t-case is at canadian tire, I think walmart has a better selection of gear oil though, I'm going to try the Castrol Hypoy C it says you don't need to add extra friction modifier.  If anyone has tried this and found you do need it please chime in.
I think there are some other places to get the special lube for the trans. but Canadian Tire isn't one of them.  Royal Purple (Mopac).  I found it easier to go to the dealership to get it.
