Author Topic: tire size question  (Read 1585 times)
superspud
tire size question
« on: January 13, 2009, 06:43:39 PM »
Hey.
well i have 215 75 15 on my jeep right now. and i could have a piar of 235 75 15. will these fit? what kind of modifications will need to be done?
i drive a 95 yj.
also what is the stock size?
thanks
Offline Whips17
Re: tire size question
« Reply #1 on: January 13, 2009, 06:54:44 PM »
The 235 75 R15 is the next size biger.  Should fit no problems.
80 CJ-7 350 chevy, 8000 Warn winch,  33/12.5 R15 Cooper STT,  True Trac front & Rear,
Offline .:.Dingman.:.
« Reply #2 on: January 13, 2009, 08:02:14 PM »
215/75/15 = 27.7x8.5/15
235/75/15 = 28.9x9.3/15
its only an inch bigger
so yes it should fit, if not most of the guys on this board have a sawzall and are willing to lend it to you.
Offline 01sahara
« Reply #3 on: January 14, 2009, 07:14:19 AM »
Hey.
and i could have a pair of 235 75 15. will these fit?
Pair as in 2 ?
I hope you plan on running 4 tires the same size and not mixing the sizes.
« Reply #4 on: January 14, 2009, 07:32:57 AM »
Hey.
i drive a 95 yj.
thanks
You will have no problems fitting 235s as the stock tire size was either 215/75/15s or 225/75/15s depending on the model
superspud
« Reply #5 on: January 14, 2009, 09:35:50 AM »
Thanks. guys
now does anyone know where to get tire swaped for cheep?
i have to swap them from another vehicle. cheapest place in calgary so far is poor boy at 160bucks.
and im a broke arse student so even that is alot.
« Reply #6 on: January 14, 2009, 11:41:08 AM »
You probably won't find it much cheaper
Offline barmanjay
« Reply #7 on: January 14, 2009, 05:29:37 PM »
you can do 31s and sawzall the flares
28s still look stock
but, i wouldnt swap unless you have all 4 the same size.
even though the size difference is miniscule, it could still do damage to your drivetrain
if you want, i have a full set of 235's on jeep steelies you can have for 200, lots of life left on them.
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
superspud
« Reply #8 on: January 14, 2009, 06:24:04 PM »
its a set of 4, i made a mistake.
and they are brand new that i am getting for free, i just have to switch rims and swap them over
Offline jeeper
  • beast
« Reply #9 on: January 22, 2009, 09:12:30 AM »
im running 31s on a stock tj  and my springs are sagging a bit and i have no problems
1976 cj5 amc 360 4.5 re "lift  35" tires 9000 pound warn
Offline 01sahara
« Reply #10 on: January 22, 2009, 09:22:50 AM »
Sounds like a great deal.
Offline dubbleJs
« Reply #11 on: January 22, 2009, 12:04:45 PM »
There's a place on Ogden road that I got 4 tires done for 70 tax in.its in the same building as race trac gas
Did you get quoted $160 to dismount 8 tires and mount 4?
« Last Edit: January 22, 2009, 04:00:28 PM by dubbleJ's »
