Author Topic: Locker Problem  (Read 1800 times)
P-Dubb
Locker Problem
« on: January 18, 2009, 03:48:48 PM »
this is the 2nd time this has happened, both while i was on the trail, my situation yesterday was i had the lockers front and rear engaged, then turned off vehicle, then they disengaged and wouldn't engage again after that, would flash as if it was trying to engage but didn't, then later on when u pressed the button nothing happened, i have funny feeling its a wiring issue, they are the stock air lockers for 2003 Rubicon, any suggestions?
Offline barmanjay
Re: Locker Problem
« Reply #1 on: January 18, 2009, 05:31:15 PM »
simple fix,.. remove axles and give to me,.. problem solved :D  j/k
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline sylvrinvader
  • the micro wheeler
Re: Locker Problem
« Reply #2 on: January 18, 2009, 05:35:12 PM »
ha ha thats a good one  :D :D
P-Dubb
Re: Locker Problem
« Reply #3 on: January 18, 2009, 06:35:51 PM »
we checked fuses and all that fancy stuff and it came back good...  :'(
Offline Whips17
Re: Locker Problem
« Reply #4 on: January 20, 2009, 08:32:36 PM »
If you have air lockers maybe your air compressor is lossing air when you are not running the motor,  Iam not a mechanic but to me it sounds like a compressor problem.
80 CJ-7 350 chevy, 8000 Warn winch,  33/12.5 R15 Cooper STT,  True Trac front & Rear,
P-Dubb
Re: Locker Problem
« Reply #5 on: January 20, 2009, 09:24:11 PM »
i have not done it yet, but i was told it could be electric lockers, and a solenoid problem
Offline mrjeep4
  • Don't forget your Super Safety Suit
Re: Locker Problem
« Reply #6 on: January 21, 2009, 11:26:17 AM »
I had a problem with my stock arb air lockers on my 03 rubicon not working.   They wouldn't engage at all  ( and no lights on the dash)  My guess was that my jeep didn't know it was in 4 low and not allowing the lockers to engage....  so i did this mod on the switch and they've been working ever since and it allows me to lock the lockers in 4 high  and even the rear locker in 2 high if i want to.
http://www.rockcrawler.com/techreports/jeep_rubicon_locker_bypass/index.asp
I did the one with the toggle switch wired into it too.
hope this helps
03 Rubicon 6" full traction long arm on 35's, warn 9ti winch,custon flat fenders and side rails
P-Dubb
Re: Locker Problem
« Reply #7 on: January 21, 2009, 05:39:21 PM »
anyone a good electrician?  ;)  ::)
Offline Whips17
Re: Locker Problem
« Reply #8 on: January 21, 2009, 07:55:54 PM »
If the switch only get's pwr when it is in 4 low then just run a pwr wire straight to the switch.  from the battery,  this whay you should be able to lock the rear in 2 hi.
P-Dubb
Re: Locker Problem
« Reply #9 on: January 21, 2009, 09:29:52 PM »
i was informed they are air lockers.. but was also told otherwise
Offline mrjeep4
Re: Locker Problem
« Reply #10 on: January 21, 2009, 10:10:59 PM »
they should be air lockers ...         that mod thing i posted    is very easy ...      looks more complicated then it is        i'm no electrician  but could give you a hand if your unsure
P-Dubb
Re: Locker Problem
« Reply #11 on: January 22, 2009, 05:55:21 PM »
would be nice lol.. i probably  cant even buy the right wires  ;D
Offline JasonL_031
    • http://www.cardomain.com/ride/2449290
Re: Locker Problem
« Reply #12 on: January 22, 2009, 10:42:37 PM »
i had same problem with my sway bar on my power wagon. i found that if you disconnect the battery sometimes that helps or if you just drive a little and then try to connect and disconnect again helps as well or just take it to a dealer lol.
1994 ZJ
6.5 inch custom lift
5.2L v8 with 5.9 exhaust
35x12.5r15 beadlocks
custom front bumper
98 leather interior
rugged ridge steering conversion
np231 tcase swap
HIDs
LED off road lights
Re: Locker Problem
« Reply #13 on: January 23, 2009, 12:32:03 PM »
Dont trust the lights. They are not reliable. Regardless of what the light does, you need to know if the lockers are working or not.
Otherwise its just speculation.
P-Dubb
Re: Locker Problem
« Reply #14 on: January 26, 2009, 05:31:51 PM »
it HAS to be a wiring issue, tried them in the driveway today, worked fine, engaged easy disengaged easy.. lol  ???
