Author Topic: Front Trackbar bushing  (Read 860 times)
Offline Elsifer
« on: January 22, 2009, 09:44:41 PM »
Trackbar bushing PN #K3176, moog 84-01 xj track bar bushing, 2 piece kit.
The autovalue by my house stocks them for me Chris (otherwise they are an order in part). I use them in most my suspension joints.
Hey Bill, is this the stock Rubi sized bushing? Or is this the upgraded one that takes the next-sized up bolt?
I'm finally getting around to replacing the bushing, and drilling the hole bigger to get the next-sized-up bolt in. Plus I'm gonna weld a washer to the axle bracket to try and double up the thickness of the bracket to keep the hole from ovaling on me.
Cheers
Chris
VA6CPL
Jeepless....
Offline Elsifer
Re: Front Trackbar bushing
« Reply #1 on: January 24, 2009, 12:00:16 AM »
Well, for those that want to know.
That part number above, is the same-ish bushing as what is stock. (for an 04 Rubi. YMMV)
I drilled out the stock holes in the axle bracket to 1/2". I reamed out the bushing sleeve to 1/2". And I used a lock washer and a nylock nut on the backside. And a regular flat washer on the front.
I even put a couple of tack welds on the front washer to keep it in place. Adds a little extra meat so the bolt doesn't oval the hole again.
Jeepie handles like a sloppy sports car again!
VA6CPL
Jeepless....
