Author Topic: On board air  (Read 1221 times)
Offline Waytec
  • not all there
On board air
« on: January 23, 2009, 10:32:09 PM »
I am putting to gather an on board air system using an A/C compressor. The information I am looking for is, what are you using as an oilier. I need one to lube pump but I am not to sure if I use a normal oilier or is their one made for Mobile applications.
The obstacle is the path.
Offline boggincj7
Re: On board air
« Reply #1 on: January 23, 2009, 11:04:28 PM »
I think what most do is use a york compressor, so you don't have to worry about lube. They have their own internal lube system, not lubricated with typical ac freon or whatever they use.
81 CJ7,304,waggy diffs,SOA,OBA,warn 8274,and always modifying.
Lethbridge Coulee Kruzers
Offline Waytec
  • not all there
Re: On board air
« Reply #2 on: January 24, 2009, 12:07:42 AM »
Thanks but I am not using a York. I am using the stock one that is not internally lubed.
Offline stroker sahara
Re: On board air
« Reply #3 on: January 24, 2009, 07:26:55 AM »
I have read somewhere that you just give it a shot of airtool oil once in a while.
Offline XJHERO
  • Soberphobic
Re: On board air
« Reply #4 on: January 24, 2009, 11:43:28 AM »
This is true and does work but gets annoying after a bit.
PA sells the self oiler you top it once and awhile with oil.
They also sell the filter so you don't spit oil in your tires.
DD
Get at me Wolf
Re: On board air
« Reply #5 on: January 24, 2009, 12:01:57 PM »
The same in line oiler for air tools can be adapted for an OBA system.
Offline calltrex
Re: On board air
« Reply #6 on: January 24, 2009, 05:20:20 PM »
the cadilac compressers are self oiling i think
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
