Author Topic: NSG370 6 Speed hard 1st to 2nd Shifts  (Read 2012 times)
Labour
« on: February 01, 2009, 07:20:40 PM »
When I shift from 1st gear to second gear it often grinds, unless I am especially careful with the shift.  Has anyone else had trouble?  Or is the synchro gear not working properly?
The Jeep is a 2005 Rubicon, and I went to the dealership and they said things were fine, but I doubt they drove it very much.
Any thoughts?
Re: NSG370 6 Speed hard 1st to 2nd Shifts
« Reply #1 on: February 01, 2009, 09:17:32 PM »
when does this happen? ive see nthis to be rather common when the ax-15 is cold. the 1-2 shift is kinda slow and can grind a little. once its warm its much better. ive seen it on the ax-5 too. if its all the time then there may be a problem. any other gears seem odd? be very sure that the clutch is all the way in as well.
Labour
« Reply #2 on: February 02, 2009, 01:54:34 PM »
It happens only when shifting from 1st to 2nd.   I have not had the Jeep long enough to notice a difference between when it is cold and after 30 minutes of driving.  So far it appear to be mostly related to how high fast I shift and how fast I am going (and how high the RPMs are) when I shift.
If I am careful, it will only grind occasionally, but it still does not feel like a smooth shift.  I don't know if this is a characteristic of the transmission, or a problem.  On some other websites people mentioned using Royal Purple (a synthetic transmission fluid) which seemed to help the problem.
-Thank you for you reply.
Offline newfie
  • newbie and loven it
« Reply #3 on: February 05, 2009, 11:44:17 AM »
mine does it too
i find double clutching it going from first to second HELPS greatly. ;D
newfies are everywhere
