Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
DIY Disco Pins
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: DIY Disco Pins (Read 845 times)
sn4cktime
UberWheeler
DIY Disco Pins
on:
February 22, 2009, 06:38:34 PM »
Okay, so Nathan and Dom gave me such a hard time about leaving my sway bar connected that they've made me extra impatient about the matter. Keeping in mind that my eventual lift kit comes with completely different sway-bar links do you guys think something like this might be alright for several months. As in, I know it's probably not THE best solution, but for a while....?
Am thinking if I can't find the right diameter pin, maybe I could use roundbar or threaded rod with a stock diameter, I don't want to oblong/tear the bushings and have it go all squirrelly on me. In the example I found he used 7/16" pins, which eventually got sloppy on him (hence the sleeving). I'll have to check, but I'm pretty sure the stock bolts are 1/2".
Logged
----1988 AMC Eagle, mostly a flat XJ at this point----
WhiteOut
Talks waaay too much!
Re: DIY Disco Pins
Reply #1 on:
February 22, 2009, 06:40:55 PM »
They should work fine. If you can find them, you should try to grab a set of pins where the loop on the end folds over completely.
Logged
dunl
Re: DIY Disco Pins
Reply #2 on:
February 22, 2009, 06:45:16 PM »
Do not, and I repeat, do NOT do any wheeling with those in there. I made the mistake on my Grand, and they bent pretty easy.
Hella time getting them outta there after that. In for pavement, out for all else, and they'll be great.
Logged
`48 CJ2A, `54 CJ3B, `97 TJ, and 03 WJ...batting close to .500 when it comes to jeep models owned vs. jeep models created.....
Red Deer Jeep Packrats
www.reddeerjeep.com
sn4cktime
UberWheeler
Re: DIY Disco Pins
Reply #3 on:
February 22, 2009, 06:51:38 PM »
Yeah, my intention was that if I did this as soon as I hit a staging area to air down (which I always do), that I'd ALWAYS disco these. Not grade 5+ hardware like the stock suspension stuff is, so I figured they might bend.
But good to know they likely WILL bend. So thanks for the heads up on that.
Any other tips? Anybody else do this before? Other problems?
Last Edit: February 22, 2009, 06:57:54 PM by sn4cktime
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
DIY Disco Pins
