Author Topic: (HELP)1980 cj7 how to tell if the volt meter is shot or if it is somthing else?  (Read 1005 times)
Offline bdron
I have a 1980 cj7 4.2L engine. my voltage meter is not working how do I test to see if it is a wire or the meter itself. I have tried different meters and still no voltage on the dash gauge.
« Last Edit: March 03, 2009, 08:32:27 AM by bdron »
What about hooking it up directly to the battery?
Offline esi
take a volt meter and check the wires that go onto the back of the gauge, one should have around 12v if your J isn't running. then check the other wire with a amp meter to a ground to make sure you have a good ground. If both the wires are descent your gauge is probably ef'd.
Formerly of Boots & Boost Inc
