Author Topic: Interior issue?  (Read 883 times)
Offline Mudhawg
  • Rig Life
Interior issue?
« on: March 04, 2009, 03:50:21 PM »
ok so my 1990 XJ has been weird since the day i bought it.. the power seats dont work nor do the dome lights and such (checked all wiring and it is good). and today i wired in an aftermarked CD player and it says its playing but no sound to the speakers? any idea's
Re: Interior issue?
« Reply #1 on: March 04, 2009, 03:56:29 PM »
"good" as in it looks good, or has proper voltage flowing through it and is grounding properly?
Re: Interior issue?
« Reply #2 on: March 04, 2009, 04:39:57 PM »
The wiring harness for the power seats runs down the driver's side door sill then under the carpet under the storage area, under the back seat. From there it goes under the carpet to under the drivers seat then splits off, goes up the tranny tunnel, feeds the tranny/t-case indicator back lights and tehn down to the passenger side seat.
Are you getting power at the connector under the driver's seat? If yes the the problem is most likey the switches. If not then trace the wires back till you do get power. If the tranny lights don't work either then the whole harneess maybe broken.
For the speakers look at where the wiring goes thru door frame. Often breaks at that point.
