Author Topic: Newbi  (Read 3833 times)
Offline Dawg1983
Newbi
« on: March 15, 2009, 08:18:36 PM »
Hi there I have An 88 yj it has a 4.2l carb is standerd i was woundering the best way to get more power out of it and any other sugested mods i plan on a 4" lift and 33" tires i would like to know easy upgrades for axles, brakes, drive shaft ect thanks
Offline newfie
  • newbie and loven it
Re: Newbi
« Reply #1 on: March 15, 2009, 10:21:44 PM »
well i  SUGGEST if you gonna lift it
1) get  a SYE kit for the transfer case- easy too do really
2) take it to DSI in SE calgary for your new rear driveshaft
just a suggestion
newfies are everywhere
Offline mike s
  • Good times!
Re: Newbi
« Reply #2 on: March 15, 2009, 11:11:13 PM »
Torque is the key to wheeling. Everyone wants more power but last time I checked it was traction NOT HP that conquered the hill. Spend your hard earned ca$h on traction and let the HP junkies waste theirs on engine...unless you only do mud drags...
oldEnuff2NObetter
but still can't help myself
Offline barmanjay
Re: Newbi
« Reply #3 on: March 15, 2009, 11:11:49 PM »
How much power do you need?
I have a 2.5 with a 4" lift and 33's and I can keep up just fine.
+1 for DSI
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline Dawg1983
Re: Newbi
« Reply #4 on: March 16, 2009, 03:35:20 PM »
Hey thanks for the help i would like to join you guys on a trail ride some time i dont have the means right now she is still stock but hoping by spring brake next year
Re: Newbi
« Reply #5 on: March 16, 2009, 04:15:58 PM »
I wheeled my Jeep in stock form for a couple years.  Watch for open stocker runs and get out wheeling
Re: Newbi
« Reply #6 on: March 16, 2009, 04:33:19 PM »
A well driven stocker will get stuck less frequently thana modified and foolishly driven Jeep.
There's lots to be said for the challenge of figuring out the right line to take with a stock Jeep through a challenging obstacle.
As long as you have front and rear tow points, a CB, and reasonable tires (not bald, and either AT's or MT''s), you've got what you need for wheeling.
I for one am more than willing to provide suggestions and a helping hand for someone that's starting out.
Offline dac
Re: Newbi
« Reply #7 on: March 16, 2009, 08:07:04 PM »
Figuring out what you want for tire size would be step #1, which looks like you've decided on 33's.  From there do lots of research on what you need to get there.  There are lots of posts here or on jeepforum.  It's always nice to ask your own questions, but keep in mind some people don't like answering common questions from the new guys(more so for jeepforum)
For me I went with 33's because they make the jeep look well rounded and funtional with out going extreme; there should also be less stress on the drivetrain and with stock rubi wheels I kept the tires tucked in, no need for new flairs and not so hard on ball joints.
I had done some engine mods when I had 31's and to be honest made it more responsive than a rubicon in stock form, mind you it was expensive for what I ended up with, but I'm still glad I did it.  With 33's and 3.73 gears I can get by on the highway in 5th just fine; if it's windy, and it has to be really windy, 4th isn't reving too high and when there is no wind 5th cruises well, can even pull most hills in 5th.  A slower 1st would be nice on the trail but than again I could use 4lo, which I don't often.
Decide what you want for gearing and lockers dependant on where you drive and how you want it to handle.  I've been contemplating truetracs because I've settled on 33's and want it to handle well on road without the quirks of selectable lockers or a detroit (my wife drives it sometimes in the winter).
Figure out what you want for a lift.  I went big the first go with the RE 4.5" SF kit.  The kit whent in easy but I had fluke trouble with my driveshaft being within spec and causing pretty good vibes.  It was a pain but I eventiually figured it out and found a shop that could fix it.  In hind site a smaller suspension lift and body lift would have worked with less stress but I didn't want a body lift.  The RE kit also rides nice.....
Decide if you can live with stock gearing with bigger tires or would rather have new gearing with stock tires if you need to build in stages.
I agree with BlackYJ, get what you need to go on the open trail runs (tow points, CB and such) to get a feel with how you want to wheel it which might change what kind of rig you want to end up with, which is where I am with gearing and some form of traction aid.
I think the best piece of advice would be if you use this as a daily driver stick with a tire that will work well with our winters.  I had a really good set of AT's on mine and it was awesome in the winter.  I changed to a set of 33" mud tires and things got a little dicy when it was cold and the ice was extra hard.  For some reason -5 ice didn't seem as slippery as -20 ice.
Take your time, decide what you want and which order you want it in and go from there; unless you have one of those magic money trees and can do it all at once :)
Offline mike s
  • Good times!
Re: Newbi
« Reply #8 on: March 16, 2009, 10:38:07 PM »
  Well stated.  Even stock jeeps are very capable machines. Remember they wrote the book on 4x4'n. Go out with others, let them tackle the nasties first and WATCH.  You'll learn what line works with what size rig. Big trucks have to right up the middle while smaller rigs get a couple of choices of lines. See where the tires slide into holes and get em stuck. Learn from others mistakes. But get out and have fun.
oldEnuff2NObetter
Offline newfie
Re: Newbi
« Reply #9 on: March 16, 2009, 10:52:19 PM »
i second the " figure out what u want first"
took my stocker out a couple of times ( not with the club  stupid me) but i found my home out there on the trails and now am building what i want.
soon as i can work again( stupid knee surgery )  and get a set of geared axles under the beast  im  comming jeep association BLA HA HA HA  ( please accespt me :-[)
but now with that rant outta the way, when u lift as i found out  u will want to re-gear to match the bigger tires as well . Now  you need to find out your own  gearing, but with 33's a set of 4.10 or 4.56 in the gears should be  sweet.
and i agree with the boys  engine upgrades are fine but spend your money in the rest of your jeep  first
another 2 cents
Offline Dawg1983
Re: Newbi
« Reply #10 on: March 16, 2009, 11:10:46 PM »
Thanks alot guys i would love to go out my tires i have now are not good at all i have some construction around were i live but they dont clear very well at all but if i could meet up with some of you and go out and see and learn thanks for all the input I live south of Calgary
Re: Newbi
« Reply #11 on: March 17, 2009, 04:27:27 PM »
Watch in the "Open trail runs" forum. There are folks going out all the time. What do you have on there for tires right now? AT's? Or do you have street tires?
Offline Dawg1983
Re: Newbi
« Reply #12 on: March 17, 2009, 04:33:22 PM »
some no name ats but they dont clear mud at all
Re: Newbi
« Reply #13 on: March 17, 2009, 04:36:29 PM »
my A/Ts like to load up too (especially the goopy stuff). but, sometimes you can use that to your advantage. just come out on a run.
Re: Newbi
« Reply #14 on: March 17, 2009, 04:39:00 PM »
Yup. AT's will work just fine during the winter months, and as long as you drive according to your rig's abilities, nobody's going to get wrapped around the axle about pulling you through a few things. As others have said, watch what others do, take the easy lines, and ENJOY!
