Author Topic: 88 YJ 2.5L rear end very noisy 410 gears  (Read 988 times)
Offline bdron
« on: March 16, 2009, 02:44:57 PM »
I noticed that the pinion moves very easy, can I just tighten it up or should I replace parts?
Re: 88 YJ 2.5L rear end very noisy 410 gears
« Reply #1 on: March 16, 2009, 08:16:43 PM »
if you can move your pinion up and down or side to side, not rotating it then odds are things are loose inside and wearing bad. you may be able to tighten the pinion nut up to keep you going but after that plan for gears and bearings.
Offline bdron
« Reply #2 on: March 16, 2009, 09:24:15 PM »
thank you for your assistance
Brian
