Author Topic: Sandblasting in calgary??  (Read 1671 times)
Offline raf2379
« on: March 28, 2009, 02:43:49 PM »
Anyone know a place that I can take my front and rear axle housing to, for sand blasting. i want to get it all cleaned up for painting.
thanks
Raf
Offline DGenR8
Re: Sandblasting in calgary??
« Reply #1 on: March 28, 2009, 04:14:14 PM »
Consolidated Compressor (9516 40 St SE)  pay by the minute, coveralls, gloves etc supplied.
_/l ,['''`'''],
l---L--OllllllO-
81 CJ7
Offline raf2379
« Reply #2 on: March 28, 2009, 07:02:36 PM »
so a pearson goes and does the sandblasting by them self? that is awesome i wish i knew of this place before. cool thanks for the info DGenR8
JUC 169
« Reply #3 on: March 28, 2009, 09:35:23 PM »
About how much per minute??
Offline yyc_tbird_sc
« Reply #4 on: March 29, 2009, 11:48:36 AM »
It'll depend on what media you're blasting with....they're setup for a few different stations. I believe the hoppers they use are about 15-20' tall.
Offline raf2379
« Reply #5 on: March 30, 2009, 03:46:08 PM »
well i just came back from sandblasting, i was there for about an hour and i paid $77, i did my front axle and the rear axle and the front knuckles. its a bit pricey, but its nice to do it your self and pay attention to detail, i got into every tight spot to make sure i did not miss anything.
Offline fug
  • Airdrie Pick n Pull
« Reply #6 on: March 30, 2009, 04:59:16 PM »
Just out of curiosity... why not just use a grinder with a wire brush and some flap disks?  I've done a few axles that way and they turn out pretty decent.  Maybe just me but hauling an axle off somewhere to sandblast it seems as much work as an hour or 2 with grinder.
Fug
TJ Rubicon
Offline raf2379
« Reply #7 on: March 30, 2009, 05:05:28 PM »
it was just way less work for me, with the carrier, knuckles and axles removed the assembly does not way much, it would take me a lot longer with a wire wheel to do both axles and knuckles, and i got in and underneath all the spring perches and all the areas that it would be tougth to get a wire wheel into.
