Author Topic: More grand guestions  (Read 3634 times)
Offline XJHERO
  • Soberphobic
« on: March 30, 2009, 09:16:03 AM »
So my buddys looking for sumthin to replace his man van.
Lookied at a 1998 grand this weekend it was the 4.0l auto  one and i was wonder if any one knows what kinda trany was behind the 4.0?
DD
Get at me Wolf
Offline 2grand4u
Re: More grand guestions
« Reply #1 on: March 30, 2009, 09:18:59 AM »
it should be the 42re thats what i replaced mine with and every thing worked great.
hope this helps
Offline LifesGrand
« Reply #2 on: March 30, 2009, 09:24:15 AM »
42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
95 ZJ v8 Ltd.
Offline XJHERO
  • Soberphobic
« Reply #3 on: March 30, 2009, 09:28:06 AM »
thanx
That sux those are crapy
DD
Get at me Wolf
« Reply #4 on: March 30, 2009, 10:12:03 AM »
I6=XJ   not worth it in a Grand, i've had one......
if he's gettin a grand get one with a V8........  the 46RE or the 44RE.  believe the 44RE came with the 5.2L.  not great trannies either but its the same combo that comes in the pickups. same with the 99-04s with the 4.7L, came with 545RFE or whatnot, same combo in the Rams.........  there are some cheap 99/2000s on Kijiji right now too Nathan
Offline XJHERO
  • Soberphobic
« Reply #5 on: March 30, 2009, 10:41:11 AM »
dads ram is siting im my driveway with a pooched auto 46re that i need to replace or fix. :(
DD
Get at me Wolf
« Reply #6 on: March 30, 2009, 10:51:25 AM »
 tushay.......... i'd still go with a V8 though.
or can u swap an AW4 into a 4l ZJ?
Offline XJHERO
  • Soberphobic
« Reply #7 on: March 30, 2009, 11:01:52 AM »
is the swap as easy in a 98zj obd2 as it would be in say 93zj obd1?
i just read it was a direct swap in the earlyer years but not shure on the newer ones
DD
Get at me Wolf
Offline LifesGrand
« Reply #8 on: March 30, 2009, 11:08:44 AM »
Sorry, just to clarify...
4.0 42RE
5.2 44RH
5.9 46RE
The 44RH is not that bad of a trans, from what I hear anyways. You can also convert the 46RE to the 4.o but this tranny still has it's issues..
If I had it my way, I'd go with a 5.9, but it's only offered in 98.
Most would advise to go with a least a 5.2 for the ZJ, the difference in gas in only ~3.5mpg, or something liie that..
« Last Edit: March 30, 2009, 11:42:30 AM by Jsun »
95 ZJ v8 Ltd.
Offline XJHERO
  • Soberphobic
« Reply #9 on: March 30, 2009, 11:27:45 AM »
i was wonderin about swaping the 46re for a aw4?
DD
Get at me Wolf
Offline LifesGrand
« Reply #10 on: March 30, 2009, 11:39:59 AM »
I know, thought some of the info may be helpful, not all...
I found you the recipe tho...
AW4 into a a ZJ with OBDII  ;)
http://www.jeepforum.com/forum/showpost.php?p=3395652&postcount=1
95 ZJ v8 Ltd.
Offline fug
  • Airdrie Pick n Pull
« Reply #11 on: March 30, 2009, 12:05:22 PM »
Or you could replace the auto with the tried and true AX15.  I just happen to have a 94 ZJ with the rare manual option (blown motor).  $1500 and its yours ;)
Fug
TJ Rubicon
Offline XJHERO
  • Soberphobic
« Reply #12 on: March 30, 2009, 12:16:59 PM »
Thanx for the tips guys
DD
Get at me Wolf
Offline 2grand4u
« Reply #13 on: March 30, 2009, 02:46:52 PM »
wow i've never seen a manual zj wish i had 1500.
Offline LifesGrand
« Reply #14 on: March 30, 2009, 03:08:09 PM »
You don't need $1500 to see it.. Give me say $500 & I'll drive you there...to look that is...  ;D
95 ZJ v8 Ltd.
