Author Topic: Transmission AX5 or Peougeot  (Read 2401 times)
henry
« on: November 03, 2005, 07:48:47 PM »
What Jeeps did the Peougeot transmission come in?  Was it only in 4.0L Jeeps or 2.5L Jeeps??  I'm replacing the AX5 in my MJ, but I' not sure if the donor transmission I might buy is an AX5 or Peougeot, I obviously could tell when I see it, but I haven't seen it yet.  Hope this makes sense.
Darren
Offline 4low
« Reply #1 on: November 03, 2005, 10:38:10 PM »
I believe the AX was available from 90' onwards......but don't take my word for it!!! 'cause I'm not 100% sure....
BTL WGN
« Reply #2 on: November 04, 2005, 12:09:54 PM »
The AX-5 was always behind the the 2.5L from the late 80s on.  The Peugeot was behind the 4.2L and 4.0L until I believe '89 in XJs and MJs and 90s for YJs
« Reply #3 on: November 04, 2005, 01:57:20 PM »
They changed halfway thru '89. There are some '89 XJs with AX15s. I believe the AX5 was only used on the 4cyl.
henry
trans
« Reply #4 on: November 04, 2005, 04:16:15 PM »
Perfect.  Thats what I wanted to hear.
Darren
« Reply #5 on: November 21, 2005, 01:38:07 PM »
If an '89 XJ (with 4.0L) has the BA10/5 puegot tranny, what's involved in swapping in the AX-15?
Different spline countS? Bolt patterns different?
« Reply #6 on: November 21, 2005, 02:27:59 PM »
probably a new bellhousing and possibly a new clutch system if you go with an external slave.  Also you will new a new t-case input gear as the 4 bangers and 4.0L w/puegot trannies have 21 splines and the AX-15 has 23.
Offline 89YJGUY
Le Bad Transmission
« Reply #7 on: November 21, 2005, 06:15:07 PM »
Here is an article that you may find useful.
http://jpmagazine.com/techarticles/29747/
Hope it helps.
